Grumpy560
1979 B7100D 4WD with B219 loader/ 3 G6200 HST mowers/ JD 310D 4X4 backhoe
B7100 D950 swap with alternator upgrade and partial restoration.
Hello everyone, I'm new to the forum. I have recently purchased a very well used and mechanically abused B7100 4WD with a front end loader. Before I start asking a ton of questions about the issues this tractor has I thought it would be a good idea to introduce myself and what I have learned about the B7100 since l acquired it on Saturday 10/18/2014 and brought it home.
My name is Steve and I live in Estill Springs Tn. I spend most of my free time tinkering around with old cars here and there. My mechanical skills are above shade tree but below professional status. I built my first house in early 2007 and of course that's when I bought my very first Kubota. The first Kubota I bought and still have is a G6200HST. This machine is hands down the absolute best lawn mower I have ever owned. It had 843 hours when I bought it and currently has just over 1300 hours now and still runs as good as it did the day I got it.
So, on with the new toy.
I've had the B7100 for about 6 days now and this is what i know about it.
It has the d750 3 cylinder and it has the flu. I bought the tractor knowing first hand that the engine would most likely need a complete rebuild but now I'm not so certain a rebuild is needed. The engine fires right up cold or at normal operating temp. However the problem I have is heavy white smoke when the engine is cold but after running for 15 minutes or more the smoke is less but not gone and its making a knocking sound that it shouldn't be doing.
The knocking sound is from the top end so i removed the valve cover to inspect. All valves are moving freely and the rockers feel fine but I'll check with a feeler guage anyway, nothing binding up there that I can see for now.
The middle injector is leaking, not too bad but bad enough to make me believe that all 3 injectors need to be rebuilt and are most likely causing the heavy smoke and i am currently working on getting them removed.
There's hardly any blow-by and I mean very minimal. I did turn the engine over with the valve cover off kind of expecting smoke to come up through the valves or crankcase but to my surprise there was none, nothing at all.
When I get the injectors out I will do a compression test on all 3 cylinders to rule out worn rings and of course a cracked head/head gasket.
Am I kind of heading in the right direction thinking that the injectors are my problem?
The hour meter reads 804 and it does work as I have run it long enough to check out the front end loader, gears, 4WD and rear hydraulics and everything works fine.
