I am told my tractor is 25 HP + or -
Arlin Oilfield
Westlock
I finally got my tractor home. The only markings that I can find on it are An Kubota LZ on the hood and a Sunshine on the front
There is a 2250 0n top of the Engine Head.
There is no tag that I can find on the transmission.
It is a 3 cyl.
Any suggestions on what size or model this might be
5,354
There should be serial number tag with your model number and horse power mounted on the transmission by you left toe if your sitting on it, if not there then it's under the floor board
Arlin Oilfield
Westlock
OK
I found the ID Plate on the frame on the left side just ahead of the front axle.
It is an L1802DT
No issues so far except that I have questions about the oil in the transmission and why it slobbers out the vent/filler cap on the top of the transmission.
Can anyone tell me where I can get a manual that would tell me what type of oil I need, where does the hydraulic oil go and how much All that stuff
1,135
OK
This problem may be due to a plugged up vent in the transmission case.
Under the seat on the side of the tractor there may be a tube sticking out that looks like a question mark (laying on its side). Unscrew it and see if it is plugged up with some kind of junk. If so clean it out and see if that resolves the problem. There may be more than one vent so look around.
Arlin Oilfield
Westlock
In one video that I saw Vic said that while using some PTO attachments one should be using a PTO overrun clutch.
Are those readily available??
5,354
Yup, got mine from fixthatford.com, had the best luck through them as far as getting one that worked. Makes a huge difference when your are bush hoging and need to stop.
