Z421
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
105
60
Minnesota
Is there some type of safety like low oil pressure or low temp at startup?
Seems after a cold start I have to let the Kawi engine run for a few minutes before releasing the brake and moving the control levers otherwise it will shut off.
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
366
146
St. Louis, mo.
I have the z422 with the kaw engine and I have to let the engine warm up for several minutes before engaging the pto are it will shut off. Seems these engines are “cold nature”
Mowbizz
Bx25d
Aug 19, 2021
644
361
I have a Z422 as well! Love it and I just winterized it yesterday…yes, warm that Kawasaki up for a good minute before you ask it to perform! Not a problem for me as I’m in no hurry!😜
Caden
1979 B7100
Apr 16, 2026
430
250
Probably best to warm it up a minute anyway, but if it needs more help, a quick blip of choke at the same time you engage the pto should keep it from stalling.
OldcrowP51
Aug 18, 2021
105
60
Minnesota
I’m maintenance mechanic/old farm boy.
I’m all about warming equipment before putting it to work.
Engine dies trying to pull out of the garage.
OldcrowP51
Aug 18, 2021
105
60
Minnesota
I let it warm up before putting to work.
I’m try to get out of the garage.
Mowbizz
Bx25d
Aug 19, 2021
644
361
mom all about warming equipment before putting it to work.
Yeah I haven’t had that problem..only when pulling up the PTO and getting the blades going before it has warmed up a bit. Moving it out of the shed is always fine. Does it happen when you bring the levers together to move?
So it dies only on a cold start…on a warm start it’s ok?
OldcrowP51
Aug 18, 2021
105
60
Minnesota
I’m not trying to engage PTO.
Trying to get it out of the garage.
OldcrowP51
Aug 18, 2021
105
60
Minnesota
Yes, only dies when moving the steer arms together when cold. (50 degrees)
OldcrowP51
Aug 18, 2021
105
60
Minnesota
This happens to me when I forget to release the brake before moving the steering levers in…🤔
I’ve done the same.
Doesn’t happen every time but have issue after releasing the parking brake.
I’m thinking parking break switch is sticking.
