Wanted: Items for B7100 HST tractor, and 1630 Loader in Canada / BC
ve7khi
B7100
Sep 5, 2026
Bc
Looking for a Top Turnbuckle Link for 3 point hitch (missing). Also, the Starboard Lift link with the turnbuckle is frozen, needs either magic, or a replacement. Neither need to be pretty!
Looking for Lift Hydraulic Cylinder Seal Kit for 1630 Loader.
Thank you - I'm new to the whole Tractor world. Runs good, just needs long overdue TLC.
7,486
Category 2 top link iz a standard item availabls at any tractor supply.
Generic aftermarket side link can also be found online.
New cylinders for about $125 each. Repkace in pairs.
Caden
1979 B7100
Apr 16, 2026
438
256
CountyLine Adjustable Category 1 Top Link
At tractor supply. You need a category 1 for B7100. May need to grind the tractor end down a little narrower to get it to fit.
That turnbuckle probably will break free with heat, lube, and persuasion.
Edit, Sorry, missed the Canadian part
I assume you still have an equivalent farm supply store, where a top link is a standard off the shelf item.
