Ultra low volume 120v oil pump advice wanted
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,235
1,213
E.
I am fab'ing up a small project and would love to find a way to pump say 1/2 gallon of used oil / hr from a tank through a tube elevating the oil say 6'. Oil would be blend of motor oils / hydro fluids / contaminated diesel and maybe very small amounts of diff. oils. Basically blended mess of used service oils.
nothing fancy in mind, a 120v pump with a manual on / off switch would work fine with goal to move about 1/2 gallon per hour. no need to be a really steady flow either. Small "burps" of fluid also OK.
any words of wisdom or advice on how to accomplish this with a small electric pump?
thanks in advance for any ideas
MapleLeafFarmer
Dec 2, 2019
1,235
1,213
E.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,104
2,528
WestTn/NoMs
great ideas but unfortunately my pea brain tells me those pumps have greater than 25 gallons / hr flow rates and I need to be in the 1/2 gallon per hour range. I would need to drop the flow rate somehow. I feel manually restricting flow rate would kill the pump through back pressure?
How about a 12 volt fuel lift pump from the auto parts store? They should be in the low gal/hr and don't seem to mind being deadheaded.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,249
1,883
Pittsburgh
Gear pump with a reduction unit betwixt it and the motor.
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
723
842
NE FL
Rig a bypass valve to return the unwanted flow to the tank.
ken erickson
Nov 21, 2010
1,458
2,759
Waupaca Wisconsin
These waste oil pumps will get you down in that 1/2 gallon per hour. This is the pump only, you would have to supply drive motor.
oil-pump-1-stage-3450-rpm-rh-rotat
5,675
When I was a transmission and axle mechanic, I built something “similar" for refilling differentials………Worked fantastic.
All I did was bolt an old oil pump (from a jeep 4.0l I think) to the top of a 5 gallon bucket, then ran it with my old sh!tty Makita 9.6V cordless drill.
I connected a rubber hose from the oil pump to the bottom of the bucket.
Took less than 25 seconds to refill the average “pig”…..Much, much faster than squeezing it in by hand.
This was before cell phones, so no pics :(
Good luck
EDIT: Here is an “internet pic” of the one I had…..
Any of you old farts remember when this bad boy was “The Bomb”?….I put many, many miles on mine for sure (y) (y)
Workerbee
Zd21
Mar 1, 2020
401
288
MN
I used the heck out of one of those too. Until the right angle one using the same battery stick came along. That little basser was indispensible.
