So you want a grapple
FloridaBoy32780
BX2680
Oct 27, 2026
27
Titusville, Fl
Many people would like a Grapple, but are crushed by the cost of the Grapple and adding a 3rd function control. I suggest you look a the "Brush Crusher" line by Westendorf. It does not require a third function control. They seem to be plentiful on the marketing web pages.
edritchey
2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75, Landmaster L5W UTV
Jul 19, 2014
1,197
977
Wellsville, PA
The model BC4215 with the center teeth are 238 pounds. The model BC4200 without the center teeth is a little less
FloridaBoy32780
BX2680
Oct 27, 2026
27
Titusville, Fl
Here's a review
As I get closer to buying a tractor, I think more about delaying the purchase of a grapple. It will always be high on my want list, But I am at $16K to $18.5K on the tractor and it is at the limit of my budget for this year. A used quick attach, ajustable pallet fork may be in my future ($300- $650 locally)
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
455
352
NH
How much does this thing cost?
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,423
1,033
Minnesota
Here is a different design that I’m considering. Have to verify it will work with my pallet forks.
7,409
Adding a DIY third function valve to most Kubota loaders is not expensive. I think these "solutions" are false economies most people will come to regret.
JMO,
7,409
$800 to over $2K depending whether aftermarket self installed or dealer ??
OR . . . .buy a TYM T25 with one factory installed
You are exaggerating. Here is a simple example of a complete low cost electric valve. I put a manual valve on my L3901 for less. It was going to be temporary but its still there 3 years later...
FloridaBoy32780
BX2680
Oct 27, 2026
27
Titusville, Fl
Show me a similar priced kit for for a Kubota BX or B series . .. . .. . and then I will be impressed.
All I have been able to find low priced is "partial" kits. Most people don't have the skills or resources to complete partial kits.
7,409
You are new here :)
What model BX and loàder and with or without backhoe. Most are almost trivial and I will be happÿ to walk you through it. The hydraulics is as simple as hooking up two hoses.
FloridaBoy32780
BX2680
Oct 27, 2026
27
Titusville, Fl
You are new here :)
Been thru the game of Metric vs SAE threads many times before. . . . . .getting the Metric parts can be difficult. Americans get confused by metric wrenches . . . . . . . let alone parts. No backhoe in my future.
My tractor decision is between Kubota B2601 vs BX2680 vs TYM T25 with respective FEL's Best price / value is on a low hour B2601. TYM has the 3rd function factory installed.
7,409
You sound like the "little engine that csouldn't"
There are very few metric hydraulic fittings on a Kubota. Tractor side is largely BSP and loader side is imperial. All readily available at your local hydraulic supply.
Have fun shopping.
FloridaBoy32780
BX2680
Oct 27, 2026
27
Titusville, Fl
Have fun shopping.
It is so easy that most tractor owners avoid it .. . .. . . . .. REALITY.
Mikeymotorbikey
B2601, Case 446, JD4475
Jun 30, 2022
45
32
North Branch, Minnesota
Not really, some of us revel in it.
With Dan's help I installed a third function, 2 rear remotes, hard plumbed TNT, and PB loop.
I have no idea what I've got into it $ wise but it was much less than Kubota or most aftermarket co's wanted. And the functionality of my tractor has increased dramatically.
The info is out there.
Mike
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,087
2,519
WestTn/NoMs
Sounds like you're leaning toward the TYM.
I'm skeptical of the mechanical grapple. Yesterday, I used the hydraulic grapple on my L35 to haul trees to the burn pile from the road ROW. Sometimes I was raking stuff up and sometimes it was better to grab it claw-like. I don't see how the mechanical grapple can give you that flexibility.
I started with forks. As you can see, they can carry quite a load.
With limited funds, I'd go with the forks and forego the grapple until I was equipped with a third function. I still have uses for the forks besides hauling brush.
