Reviving An Old Acquaintance Buried In The Pole Barn
7,429
Kernersville.
About 1.5 hours from my friend Jack. We workef together and he snd another coworker/ friend retired 20 years ago. Theg both moved to Raleigh/Sanforx with the stated goal of playing every public golf course in the state. I am sure he has a list in your area and he has prob as bly taken me to ond or more. I would be remiss if I did not ask - do you play golf? Driving around in a cart wjth clubs and cc a cooler of beer qualifies as a yes. :)
6,930
I have hit a golf ball in the distant past. Just enough that I either needed to start playing or stop playing. At that point in my life, stopping was the obvious choice. And I will warn you, I don’t drink, but most all my friends do. (Unfortunately, moderation is not one of my strengths.)
Riding around in a cart with clubs and pretending like I can sort of play golf, that I can do. 🙂
pigdoc
G1800S L2500
Aug 19, 2022
417
361
SE Pennsylvania
Speaking of Pennsylvania Panzers, there’s one of those on the other end of that same pole shed. For several years, it wasn’t running. Couple years ago, I got it running just because non-functional items bother me. Parked it and haven’t moved it since as I have no use for it beyond sentimentality. It was my first lawn mowing experience. Another piece of equipment where safety was way down on the list of design criteria.
In good running condition, that Panzer could bring $2000 (or more) at auction. I forget what engine they had in them...
- Paul
6,930
- Paul
That one has a single cylinder Kohler K181 according to the very official looking red paint on the engine. Shockingly, I had no trouble finding a service manual online for free download.
The mower itself is a T758ES. I had always thought it was from the 50’s or earlier, but researching it when I was looking for info to fix it, it appears to be from the mid-60’s.
I would sell it, the Farmall, and both Troybilt Horses but my brother seems to be attached to the Panzer and Farmall despite his having nowhere to store them. I suppose they’re not really hurting anything here, but I’d rather they be with someone who would really enjoy and appreciate having them. IMG_8234.jpeg IMG_8233.jpeg
6,930
Spent some more time on this project today. So much time if I was getting paid by the hour I would have had a great day. If I was getting paid by the job, I would have lost money. I wasn’t getting paid at all, and eventually got things functional so I suppose it was all good in the end.
Several days ago, had a look at the over run clutch on the Farmall to see if it had the requisite through hole. It did. Of course it couldn’t be that easy. Started looking at how to get it off as it wasn’t obvious. Turns out there’s a grease zerk on one side and a set screw 180 degrees away on the opposite side. Took out the set screw. Turns out wasn’t holding anything. It’s just acting as a plug so you can remove the set screw and zerk to drive out the roll pin that’s driven through the hole in the underlying PTO stub. So you have to have a PTO stub with a hole in it to install this thing. Useless for this project. IMG_8241.jpeg Looked all over the internet and found this thing. Multiple suppliers had it available with prices from $12.99 to $70.00. Looks like they all come out of the same Chinese factory regardless the retailer. We have Walmart Plus which does away with shipping and it was returnable to the local store if it was junk, so I ordered one. IMG_8378.jpeg IMG_8396.jpeg So far as quality, the Chinglish “key item features” clearly states “you do not need to worry about the quality” so it must be a high quality item. Right? Yeah…
It didn’t fit on the tractor PTO stub. Went on about 1/2” and stopped. Like it was broached with a worn out broach. Great…
Hoping it wouldn’t take much to get it to fit, started grinding it out with a Dremel yesterday toward the end of the day. Made good progress in the 30 minutes I had to work on it. Ended the day thinking it needed about 1/8” more to lock on. Started in on it this morning. Actually needed about 1/2” more. Despite yesterday’s success, seemed like I might as well needed a mile. Couldn’t use anything bigger than the Dremel because it had to be pretty small to fit in the hole and had to grind the grooves and splines separately. Had to take breaks due to the front bearing in the Dremel heating from the stress.
During one of those breaks, noticed a pneumatic die grinder hanging in the wall that came in a set of air tools about 25 years ago. Used it maybe twice in that whole time so I didn’t think of it. I could almost hear it saying, “Put me in, coach!” Switched to the die grinder and that sped things up a bit, but it was still painfully slow. After 3 hours (kind of embarrassing, but yes it was 3 hours of screwing around with it) finally had it on far enough the get it completely past the groove in the tractor PTO stub but not far enough for the locking pin to engage.
In the spirit of @JoeSmith and in keeping with the general theme of this implement, I gave up on re-grinding the splines and decided to drill and tap it for a 1/4-20 set screw to seat in the groove in the tractor PTO stub. It was hard, hard enough the swarf came out in little chips instead of curlies, but it got done without drama.
Now it has a positive connection to the tractor. Thankfully the male end fit the female end of the auger without modification. IMG_8385.jpeg
6,930
Didn’t do anything spectacular to store it. Just dumped it on some pallets to keep it out of the dirt. IMG_8242.jpeg
Wrestled it back on the tractor. IMG_8388.jpeg The PTO shaft angle fully raised is pretty extreme, but it wouldn’t ever be running fully raised. With the extension not much worse than without. IMG_8389.jpeg
Last thing for today, the lower lift arm triangle connection to the boom is adjustable. Further back is less range, more power. Further forward is more range, less power. It was set pretty far back for the 9N which had a lift capacity about 800lb. IMG_8390.jpeg The L is more like 2300lb so I loosened the clamp bolts and moved it forward to get more clearance for trsvel. IMG_8392.jpeg
Now, fully raised the PTO angles are far too severe to run, but it wouldn’t be running fully raised and it’s not the only implement I have that has excessive PTO angles in transport position. IMG_8393.jpeg
Next, figure out an efficient way to store it. Have a few ideas, but that’s another day.
