Re-install lower boom pin on BT600 on BX23D
Hauland
2005 BX23
May 2, 2013
Round Hill, Va.
I removed bottom backhoe boom pin to replace hydraulic lines on boom cylinder and need some help on how to align keeper bolt once pin is reinstalled.
The pin has a recessed grease zerk in the face of one end and a flat face on the end with keeper bolt hole.
The lines running underneath the bottomw end of cylinder are a hassle to get out of the way and i assume will self adjust some once cylinder is mounted, however it is worth noting my replacement hose is a larger diameter and in the future as more hoses are replaced this could be an issue.
The pin is a tight fit and i cleaned the pins and holes and used fresh grease i have managed to wrangle the hoses and get the pin through several times but the keeper bolt hole is misaligned and i cannot rotate the pin.
Do i need to keep trying or sand pin and holes to allow rotation or possibly weld a nut on solid face to rotate or is there something i am missing?
4,320
Do not “sand” or reduce the pin or open clearances. (What is the point of lubricating it if you are planning to deliberately make it under-sized anyway…? ..and if you want a sloppy boom…then that is what you’ll get if you open clearances.)
Remove the pin, align it properly, then drift it back into position to install the bolt.
Hauland
2005 BX23
May 2, 2013
Round Hill, Va.
How do i maintain alignment while drifting the pin in place?
I align it , drift it and by the time its thru the keeper bolt hole is out of alignment.
It was 3/4 aligned one attempt but i couldnt rotate pin to fully align hole. I tried punches/drift in bolt hole to align but got no rotation.
4,320
I’ve never had that problem… so I’m imagining a possible solution:
Install the bolt in the pin….and keep the pin in proper alignment as you drift the pin into position as far as possible. (use the bolt for leverage to keep it aligned while drifting the pin.)
Tap the pin into position as close as possible…remove the bolt as late as possible in the process…so that the pin only needs to be moved another inch or so….
Perhaps that method will reduce the amount of mis-alignment…so as to allow insertion of the bolt after that last inch or so is accomplished.
