RCK60D-26BX How do I get the Gears Out?
sphanco
BX23S
Sep 5, 2026
Greenbrier, TN
I am rebuilding a RCK60D-26BX gearbox because the vertical shaft has play from side to side and is wearing the pulley as well as throwing the belt. I have the gear box off the mower deck and have removed the top cap, bottom seal, horizontal seal, and horizontal c-clip. I do not understand how to remove the shafts. All of the videos i could find show another hole in the case opposite of the PTO shaft that they use to remove the horizontal shaft but that does not exist in the RCK60D-26BX gearbox. There is another c-clip on the top of the vertical shaft holding it in place but I cannot get to it with out taking the horizontal shaft out first. Any advice?
whitetiger
Nov 20, 2011
3,812
2,217
Kansas City, KS
Working through the large opening in the top, drive the bearing for the input shaft out of the case.
sphanco
BX23S
Sep 5, 2026
Greenbrier, TN
Thank you! It took a little persuasion but worked with a punch and hammer and managed to get the bearing out along with the input shaft. The rest was pretty easy to get disassembled. I had to order a few more parts after I got everything inspected and I now have it put back together and everything runs great.
Bibi38
Kubota BX23S
Sep 24, 2026
NY
No access hole on that model, so you're right,the manual won't work. The trick is to drive the input shaft out from the pulley side with a punch. Once that's out, the freeze plug on the side of the case lets you get to the rest.
