quick spade
netspyder
L3010HST
Jun 9, 2025
52
92
Missouri
has anyone used one of these? advertised in the 80's or 90's as the be all end all for trenching if you don't have an excavator, backhoe, or trencher handy... videos depict dragging boulders out of the ground... i'm skeptical. that being said... i did buy one. the finest chinesium money can buy, i'm sure. titan attachments, so you know it's fine chinese steel. this guy can go on the front of the bucket or slide onto pallet forks. the bucket option seems terrible and likely to bend the cutting edge... but the pallet forks i think might be a usable option. get me deeper - where i need to go for water/electric service. i rented a 2T mini ex and that guy could not make a dent in the rocky clay that passes for ground in mid-mo where i'm at. i've thought about renting a 12k excavator but i'd have to have that delivered. my lil taco can't hope to pull that. also thought about renting a trencher but i have concerns about roots and rocks and what they might charge me for repairs if things go sideways
anyway - i expect to get a ssqa conversion kit and forks in january and will test drive this and see how it goes
KevinM_WI
Kubota L4060 4WD
Nov 17, 2026
Wisconsin
Haven't used that exact one, but I'd take the sales videos with a pretty big grain of salt. Rocky clay can make a lot of attachments look pretty ordinary in a hurry.
I agree the bucket mount would make me a little nervous. The pallet fork setup seems like a more reasonable option, but I'd still want to check the attachment ratings and be careful about putting twisting or side loads on the forks and loader.
It might be useful for loosening a spot or working around rocks, but I wouldn't expect it to dig a clean, consistent trench like a trencher or excavator. If you're going ahead with water or electric service, I'd also make sure the underground utilities are marked before digging.
Caden
1979 B7100
Apr 16, 2026
438
256
Well a pic might be helpful cause I've never heard of a quick spade - but I googled it and got the idea.
If you plan to use it on forks... just remember that forks aren't really designed to apply any down pressure, or for prying
It would seem to me that if a small excavator wouldn't touch it, than the fel on your tractor is probably not going to to cut it either.
Perhaps you might have more luck pulling something from behind your tractor, like a single ripper shank.
Tim Horton
319
84
Lake Superior
Trivia..
There was a time in orchard maintaince and the like I considered a FEL tree spade type attachment.. Fortunately.... I was able to get most I needed done with a Pirahana tooth bar on the FEL and a 3pt subsoil ripper.... Depending on your ground, I would be be rather careful with a FEL attachment as to not tear up your loader..
BX23-S,57 A-C D-14,
6,345
Maybe buy a proper subsoiler for your tractor. Mine would go down 2 1/2 feet, sure might take 2-3 passes but it really loosens the soil up. Where I am , for water service ,you need to be 4; down ,so my BX23S easily does that. NOT fast,but it does the job.
netspyder
L3010HST
Jun 9, 2025
52
92
Missouri
In clay and rock I think your going to be very disappointed!
i often am. it's something i've come to expect by now. when i first bought this property, i needed to put in a mailbox and a couple posts for a driveway gate. the one person gas auger barely scratched the surface, tweaked my wrist, and took me for a ride more than twice. went and rented a pull behind gas phd and was able to get the mailbox set but even that wouldn't do the gate posts. thats when i bought the tractor and the 3 point phd. still took me a few tries with that and more than a dozen shear bolts.
i do have a middle buster and that can get me started. that'll only go down like 18" and the frost line here is 26". i can rent a walk behind trencher that'll do 8" x 48" for like $300 for a weekend but i worry about breaking that. it's one thing to break my own stuff but another to break a rental.
hedgerow
493
481
Malcolm NE
I wouldn't waste my money on a quick spade. We own and farm a fair amount of ground that has lots of clay and rocks. I have ruin my fair share of three point post hole diggers building fence. You learn quickly to buy or rent the proper tools to do the job or just hire someone with the proper tools. I have a heavy post digger for my skid steer and rock bits for it. When we have need water lines, sewer lines or electric lines ran we have rented trencher's with rock teeth or hire someone with the correct trencher. No need tearing up a front end loader on a tractor trying to make a digger out of it. I also understand its tough to get someone out to the country to do digging work. Its not easy in my area. Too much work in the city for them to come out.
11,559
Get rental insurance / damage waiver insurance when you rent equipment.
One oops and it will save you a ton of headaches.
6,991
A bit more seriously, if your soil and rock content is typical for your area, it shouldn’t be difficult to locate a trencher with rock teeth (carbide tipped nubs). They’re made in both wheel type and chain type. Buy the damage waiver and if it breaks swap it out for another one. Small ones are a bit of a rough, slow ride going through a bunch of rocks, but they’ll get it done.
timber and wine
L4802, loader, forks
Nov 1, 2026
52
50
NE WI
If a mini excavator can't handle your ground that spade thing has no chance. I have heavy rocky soil and thought about getting a backhoe attachment but after watching a mini ex struggle with it I figure if I need a hole I'll hire a real excavator to do the job.
I'm still out on a PTO post hole digger. My neighbor used his skidder with a 12" auger to dig the holes for my trellis posts and when he hit 3' the whole machine would buck like a Broncos and the auger would start screeching as it scratched the ground.
A mans gotta know his tractors limitations!
Elliott in GA
Mar 10, 2021
886
903
North Georgia
As noted above, rent a trencher with the Insurance. I rented a tracked Vermeer trencher for less than $180 to cut a 180 foot trench for electrical through clay and rocks (softball to football size). I completed the job and returned the trencher in less than 4 hours; the rental place was 45 minutes each way.
It cut through the hard red clay and rocks without so much as a pause. When I was done, I had an easy to cover uniform depth trench without any excess mess.
