pressure relief tools for flat face couplers
BigO 6060
L5030 sold/ L6060 sold/ L6060CAB/ ZD331 sold/ SVL97-2/Case CX130D
Apr 24, 2017
26
SC
Has anyone tried any of the pressure relief tools for flat face couplers? I am seeing one on my FB feed (tractorreleiftool.com) that looks like it may be useful. Have seen other similar. I have a faster quick coupler on the L6060 so no probs there, but on the SVL97-2 and the Case Cx130D excav hooking up munchers and mower attachments can be a challenge sometime. I’m not a spring chicken. And I don’t like cracking a fitting loose each time this happens. Just would like opinions. Thanks
edritchey
2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75, Landmaster L5W UTV
Jul 19, 2014
1,195
975
Wellsville, PA
I've fought with flat face fittings on my loaders 3rd function connections for years and probably collected every tool to make them connect and made some myself then I found the screw connect flat face fittings and have since changed out all my 3rd function loader attachments for this new type of fittings no more screwing around they just go together with or without pressure on one or both sides. I also have an adapter to use on rented attachments when I need it to connect to my loader outlets. No fuss no mess.
Watch this video the last set he shoes are the screw type I'm referring to they are the cats ass.
VIDEO HERE
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,388
909
under a rock
Looks like a handy tool to keep in the cubby.
a little $pendy but probably worth it ...... if it's a reoccurring problem.
I say go for it. you can't take it with you Grandpaw... $$
I like the idea... of course my brain is thinking I could probably make one iffin I didn't have 500 other projects... :ROFLMAO:
BigO 6060
Apr 24, 2017
26
SC
Yea kind of at the same point. Time is gettin valuable the more it runs out, so I “do it yourself” a lot less often.
#40Fan
675
500
Hook the hoses together on your implement after you remove it. Not only does it keep them clean, it keeps pressure from building up on one side.
mikester
M59 TLB
Oct 21, 2017
4,163
2,854
www.divergentstuff.ca
Removal: turn off tractor, actuate valves to depressurize the lines, then disconnect.
Reconnect: turn off tractor, actuate valves to depressurize the lines, then reconnect.
Don’t leave your implements sitting in the sunshine or learn to live with the consequences Aka suck it up sunshine!
BigO 6060
Apr 24, 2017
26
SC
I appreciate all the responses.
I am sure mainly the guys with tractors will also gain some insight here. As stated in the OP, I have Faster connectors on the tractor so no prob there. Regardless of hose, switch, lever position, etc I can hook up easily.
While some of the advice applies to excavators and skids, things like keeping the implement out of the sun is not a 100% reliable option without keeping the implement indoors. My lean too’s are 12’, 16’ and 20’ and get sun some part of the day. On top of that while direct sun is worse, SC summer heat can increase hose/ tubing pressure on its on shade or not.
