Pinion Shaft Removal RCK60-29B mower
Geech
B2620 with RCK60-29B mower
Sep 26, 2026
PA
I'm attempting to replace the bearings in the k5781-33102 gearbox on my RCK60-29B mower and I'm struggling with how to remove the input pinion shaft (#180) from the bevel gear (#190). Can someone provide some guidance on the right way to extract these parts so I can get to the blind bearing on the other end of it? Thanks in advance!
whitetiger
Nov 20, 2011
3,824
2,225
Kansas City, KS
With the input shaft seal and bearing retaining snap ring removed, the shaft can be driven out of the gear case using a shoulder near the center of the input shaft. The input shaft is turned down where it sits over the output shaft and gear, creating the shoulder.
Geech
Sep 26, 2026
PA
Thank you, that got the job done!
