Paint for bare steel homebrew attachments?
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
618
648
Lake Almanor, Ca
I have used rattle can Appliance enamel with epoxy. 1 step...works great...easy to fix.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
129
119
Lopez Island, WA
I find single part moisture cured polyurethanes to work really well. One (over-advertised) product is POR-15; there are other sources. Some have aluminum powder mixed in... excellent primer. Not cheap, but a quart will likely suffice. Very tough. Can be top coated with your favorite spray enamel, or you can leave it silver looking.
Aluthane is one brand I've used; there are lots of others.
- Bart
mike paulson
233
ulster, NY
All this talk about what paint! Has anyone for a minute thought about what wax to use to maintain that new paint lusty luster on that log Arch?
Tim Horton
312
81
Lake Superior
If you look up the worst painter in the world, there is a picture of me.... With that in mind...
In the basement for the winter.... I have part of a gallon of International red, and part of a gallon of JD yellow paint..
When needed, I just cut the skin off the top of the paint, and use as it is.. The prep I use is to go over as much as I can with a wire brush on a 4" side grinder. Then a rag of acetone or alcohol depending on what is available. When dry, I paint and let dry for a week or so before moving.. It actually takes 2-3 weeks to be set the best.. I'm not impatient about letting it cure.
I'm not particular about color, or show room quality of the job.. Protection of the implement is my concern.
