Only Want Dash Lights to Come On, B2601
ShaPow!
North Idaho
So I installed a decent LED front facing light on the ROPS for better night time visibility while pushing snow. The snow plow blade and SSQA mount do a decent job of blocking the stock head lights. AND, more than that, there is a pretty good amount of light that bounces back at me that makes it harder to see. Kill the headlights and just run with the ROPS LED and all is good. Except for the dash lights--I can't see the gauges.
I queried around here looking for similar posts but failed. Seems that my headlight switch has OFF and ON, with no detent for just the dash lights. Am I missing something (and it totally could be me-my wife heckles me all the time about "not being able to find stuff"--TRUE).
If this is truly the case, my solution was going to be to wire up a relay to be able to control the stock headlights so I can flip the headlight switch, then choose either dash lights without headlights or with headlights. I could just unhook the headlight bulbs, but too easy! Am I missing something simple?
BX23-S,57 A-C D-14,
6,344
For my BX23S, I use a 4 channel RF wireless relay box. 'a' controls the garage door opener, 'b' for back facing LEDs, 'c' for side LEDs, 'd' for front (driving) LEDS. Power from the harness out back under the blue tape. Hay, it works for me, was easy. Agree stock headlights are USELESS with bucket up front !
b2601scott
Kubota B2601
Nov 10, 2026
10
Central Michigan
Same tractor here. No idea if there's a dash-only position on these, so I'm no help there, but I'd want it too. Post back if you find a clean way to do it.
Ping
BX2370-1
Dec 25, 2018
385
411
Troy, Ohio
I don't own a B but, why not just unplug the headlight bulbs from the harness and call it good for the winter?
JasonW
931
637
Al
On my older L series I just unplugged the headlights. I could see my dash/gauges with the ROPS though. I liked to keep the “headlights” on also just to have the taillights on also.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,246
1,225
E.
I snow blow almost exclusively at night and thats what I do. I pull the bulbs. Leave harness in place though as I worry about wetness / corrosion from an unhooked harness. Doesn't seem to bother computer or anything like that either.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
203
202
If the dashboard lights are anything like the headlights, they're really dim.
I wonder how difficult it would be to pull out the oem bulbs and drop in some LED's and brighten up the dashboard?
ShaPow!
North Idaho
Mine are OK as is. Don't imagine it would be too difficult to put LEDs in however.
BX23-S,57 A-C D-14,
6,344
Possible solution though $$$$. Find mfr for the existing switch ( 6C41030810 ) and check for similar WITH 'dash light' position. I have(had ?) that information for the 'light switch' for my BX23S....at least 6-7 versions ! When I added LEDs, I used a 4 channel RF relay unit with key fob remote. Made wiring easy and I got a remote for garage door opener.
