Not a north American MX5200, workshop manual issue
PaulL
B2601, MX5200.
Jul 17, 2017
2,820
1,806
NZ
My dealer (in NZ) tells me that it's impossible to buy the WSM for my machine. Now, it's a NZ spec MX5200, so that means no DPF and none of the tricky bits you get in the US - probably similar to a pre-tier 4 machine in the US.
I did find a WSM for an MX5000 from around 2000. There'll no doubt be some commonality, but that's pretty old.
Does anyone have a source for a WSM?
11,545
Sadly your dealer is probably right.
The closest match might be a MX5100, The MX5000 is much different and much older.
Take a look at it and compare to what you have in front of you. ;)
PaulL
B2601, MX5200.
Jul 17, 2017
2,820
1,806
NZ
curious.....shouldn't the dealer have a WSM or did they not sell the tractor ??
They say they have it, but it's locked down in a way they can't export. Which may or may not be true. I think Kubota are getting tighter on these things, and my dealer isn't one to push boundaries.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,246
1,225
E.
DPS in Brisbane should have what you want. Or at least they should be able to point you in the right direction.
whitetiger
Nov 20, 2011
3,851
2,243
Kansas City, KS
It has a V2403-E-CDIS engine. It is listed as being a V2403‑M‑T, which is mechanical injection with a turbocharger.
Engine
No code has to be inserted here.
Kubota’s revolutionary centre-direct injection system (E-CDIS) engines offer more durability, power and fuel efficiency. Turbocharged, inter-cooled and 4-valve-per-cylinder engine technology offers higher torque and incredible pulling power. The MX5200 offers 50.7 and 51.2 net engine horsepower. Our 5200 gear model delivers 45 PTO horsepower, giving you the power to work more efficiently. These tractors feature a built-in balancer that helps minimise vibration and noise.
