New to Me Kubota L225
WisconsinWhitetails85
Kubota L225
Aug 9, 2026
12
Wisconsin
Hi folks,
I just bought myself Kubota L225 and I've run into my first problem...of many to come, I'm sure.
The three point hitch lift is incredibly weak. Standing on the draw bar, it will lift my wife 130lbs but not me 250lbs. I also have a rear scraper blade it will not lift.
Fluid is full. Valve under the seat is open. Based on what I'm seeing online, it's possible that the pickup screen is clogged but that seems kind of unlikely to me as the fluid is pretty clean. I also have no idea how to get to it to clean it...so I haven't physically checked.
What else could be causing this? Other than that, it runs like a top and drives the woods belly mower with no problems at all.
I appreciate any thoughts or advice!
3,185
You may want to verify the pump pressure before doing too much but it sounds like you might need to replace the o-ring and backup ring on the piston that lifts the three point hitch.
There was just another thread that showed how to do that so I will try to find it and post a link.
Here is the link (but it was a different model tractor, but similar age and issue)
Kubota L225
Aug 9, 2026
12
Wisconsin
I watched that video. I think that is totally what's happening. Off to find replacement o-rings!
Kubota L225
Aug 9, 2026
12
Wisconsin
Hi All - looking for some more guidance here.
I ordered seals and replaced everything in the 3 pt hydraulic piston. It is still super weak. I have very low hydraulic pressure. The hitch will lift about 150 pounds.
The good news, it now stays in place once it's raised. There is essentially now loss of pressure once it is pressurized and the lift lever is placed back in neutral.
So, going down the next rabbit hole. What would you all recommend next? I bought a new hydraulic filter and am planning to drain the tank and install it when it arrives.
Would you fill with SAE 80, or UTH?
Other than the filter, what should I dig into next?
Thanks in advance!
3,185
Kubota L225
Aug 9, 2026
12
Wisconsin
Use a UTTF like this
You should start by testing the pressure in the system. I believe there is a port near the speed control knob that can be used to check the pressure.
If you don’t have a Work Shop Manual you can get one here
Thank you! I am working on trying to test the pressure - would you have any idea what size the threads are for that port? I have a thread checker and the plug didn't seem to fit anything I had on there. I'm guessing it's some type of uncommon fine metric thread.
3,185
The port is probably a BSPP thread. That will have an inch size thread and the threads are parallel. There should be a sealing washer under the plug’s head.
See this link for dimensional information
Kubota L225
Aug 9, 2026
12
Wisconsin
Ok, got the fitting figured out and got a pressure gauge hooked up. Only getting about 400 psi at the port on the lift cylinder cover.
As a test, i raised the hitch all the way up and put some weight on it. Left it like that all weekend, and it didn't drop an inch. So I'm fairly sure the cylinder is sealing properly at this point.
I tried to check the overpressure relief valve. Visual inspection looked ok, but then again I'm not entirely sure what I'm looking at. I read some posts about shimming the spring to test it, which I did. Didn't seem to help.
Early this week I'll be changing fluid (going to UTF) and putting a fresh hydraulic filter in.
If that doesn't fix the issue, i guess my next thought would be the pump itself.
Does anyone have any thoughts?
Thanks in advance!
3,185
Well that pressure is really low. Was that trying to lift something on the three point hitch or just a static condition. You need to be doing work to get the pressure up. You can try to lift more weight than it is capable of to force it into relief. Lift something really heavy or chain the arms down to an immovable object and try to lift. You should hear a squealing sound and the pressure should be around 1500 to 2000 PSI (if my memory is good).
Just to be sure of a few things…
Have you cleaned the strainer in the transmission case that is for the hydraulic pick up? If not, that could be limiting the flow through the pump.
If the pressure doesn’t rise, you could verify that the pump is actually moving (or not moving) fluid by connecting a hose to the same fitting in the pressure port with the open end feeding back to the transmission fill port. It should be moving 4-5 GPM.
You need a Work Shop Manual that is available here
Kubota L225
Aug 9, 2026
12
Wisconsin
Changed the UTF and filter. It's somehow worse now than it was before. Confirmed 5.8 Gallons added. It will not even lift 50 pounds now. I also do not hear any squealing noise, or really any noise at all when I try to lift the cylinder. I'm sort of out of guesses other than the pump itself. I ordered an el cheapo on amazon, we'll see if that's the issue. If a new pump fixes it, I'll probably try to find something of higher quality somewhere.
Edit: Haven't been able to test flow yet - need to find the correct fittings. I suspect it's not moving much.
Kubota L225
Aug 9, 2026
12
Wisconsin
It was the pump this whole time!
I replaced the pump today, which was an awful experience, and that did it. The 3 point lifts heavy stuff without breaking a sweat.
The way the nuts are situated on the rear studs of the pump was torture. It took me forever to get the off and on again.
I'm really excited to start doing more with it now.
It has a 59" woods belly mower that is awesome, just shreds whatever you roll over. Next up is starting to get all the trails cleaned up and skidding some logs. Deer opener is a couple months away!
