New old tools
5,622
Hey, you gotta do what you gotta do with what you have. I've seen people disassemble machinery and lay planks and ropes down staircases to get it in or out of a basement workshop. Your operation looks pretty straightforward.
5,622
I've started having a play with the new lathe - finding little things that need sorting out.
Here's a few specs:
Motor - Chinese 3 HP single phase reversible.
Diameter over bed - 360 mm (14").
Diameter over gap - 600 mm (24").
Headstock bore - 40 mm (1.5" plus a bit).
Bed length - 1660 mm (65").
Between centres - 1380 mm (54").
Weight - a lot.
Slowest speed as is - 40 rpm with back gears
Auto feed - forward and reverse saddle and cross slide.
Screw cutting - metric and imperial.
4 jaw chuck - 300 mm (12").
3 jaw chuck - 260 mm (10.5") Taylor conical/tapered scroll chuck with reversing jaws (I'm told they were the Rolls Royce of chucks in their day - I think their day was 60 years ago) - only grips down to 16 mm DIA.
Faceplate diameter - 400 mm (16").
Steadies x 2 - fixed and travelling.
There's also a whole bunch of tools, a few drill bits, a good 3MT drill chuck, several Morse taper adaptors, a coolant pump. Fit no extra charge there's some dodgy wiring and no emergency stops, no guards over belts - these will be addressed.
Pretty happy with the purchase.
Here's a video showing the operation with back gears engaged - I made this for the gentleman I bought lathe off. He had never used a lathe when he bought it and didn't know what back gears were. He asked if I could keep him updated with it's progress as I get it up and running. He lives fairly close so he'll probably drop in to have a look too.
Feel free to correct me on anything I've messed up here - as I've said before, I'm no machinist, just a retired engineer trying really hard.
One problem was the pin that engages and disengages the chuck shaft to the pulley shaft. With the pin pushed in the two shafts are locked together and you get three "high" speeds dictated by the flat pulleys. With the pin pulled out the two shafts can spin independently - this allows the back gears to be engaged to get really low speeds.
The problem with the engage/disengage pin was that it's top end was broken off so it wouldn't hold in position properly. The next problem was that it couldn't be removed as it hit the casting behind the chuck - I didn't really want to disassemble the main shaft just for this. Serviceability obviously want on the list of requirements when the lathe was designed.
The original pin was all one-piece and looked like this - 16 mm DIA x 40 mm, 8 mm DIA x 65 mm.
There's no way to get it into or out of the hole it goes in as it's too long. To get the original pin out I had to gradually cut bits off until it was short enough to come out, then it was too short to do the job.
I decided to make a new pin in two pieces. The larger diameter piece with a M8 thread through the middle, and a cut off M8 bolt that screwed into it.
Screwed together with the same dimensions as the original pin, there's no way it's going in the hole.
But pulled apart, I could push the larger diameter section into the hole....
The hex key is in a small hole in the 16 mm diameter piece. It's there so I can stop it turning while I screw the cut-off M8 bolt into it.
Then I could screw in the cut off M8 bolt.
Here's the finished assembly with the pin extended and retracted. I added a M5 bolt through the other end of the M8 section of the pin. This, with the help of the original spring and the original but modified nut, allows the pin to be locked in the extended or retracted position by rotating 90 degrees.
Now I'll assemble it back in the lathe with a drop off Loctite.
I modified the nut by milling the deep slot wider to fit the M5 bolt - that was the first job for the new mill.
Damn it Man!!!!!
I gotta stop reading your posts and get busy, you're making me look lazy🍻🍻
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
887
1,670
Baranduda, Victoria, Australia
Nice!
That is an unusual-looking chuck. Any chance of a face-on view?
Here's a link to some info on the weird looking chuck.
Paul Allwood
Jul 8, 2025
887
1,670
The Taylor 3-jaw chuck feels really smooth and comes with reversing jaws.
I'm planning to fit a ground bar and clock it with a dial indicator to check it for runout. If it checks out ok I'll keep it and use it.
The only problem I can see with it so far is that it can only grip down to 16 mm (5/8") diameter. I'm thinking I could hold bits of something accurate, maybe key steel, on each jaw, but that will be fiddly and awkward. Has anyone had this issue with a large chuck and come up with something better ?
torch
Jun 10, 2016
2,897
1,148
Muskoka, Ont.
No I haven't, but maybe some sort of "collet system" would work?
That's what I was thinking. Grip a hex 5C or ER series collet holder in the chuck. Or mount a small 4-jaw chuck to a mandrel and grip that in the chuck.
Paul, I applaud your creative solution to the pin problem, nice to get things back to spec. But as mentioned earlier in this thread that motor is screaming out for a VFD (Variable Frequency Drive), especially if you don't already have 3 phase power in the building. Gears, pulleys, pins? HAH! Just turn the dial to set the spindle speed with precision.
Paul Allwood
Jul 8, 2025
887
1,670
Thanks. An electrician friend will be helping me with the wiring updates. He had a look at pics of the motor wiring inside it's terminal box and told me it's not suitable for a VFD. Not sure why ?
torch
Jun 10, 2016
2,897
1,148
Muskoka, Ont.
Some older motors don't have adequate insulation or cooling capability. I don't know that you can tell from the terminals but the rating plate should provide the required info. Too bad, variable speed is a real nice feature in a lathe.
Paul Allwood
Jul 8, 2025
887
1,670
I have a question for you guys more experience with mills and milling than me, that's pretty much everyone.
The thread in the top end of my collet chuck is 1/2-12. The largest diameter that can fit down through the spindle is a little over 3/8. A previous owner of the mill had a go at making a drawbar by "welding" a 1" length of 1/2-12 thread onto a piece of 3/8 threaded rod. Both are soft and both are damaged from use. This setup also means that the drawbar can only be removed from the bottom.
It would seem to me to make more sense to be able to remove the drawbar from the top so I don't need to raise and lower the head of the mill if I want to change from a drill chuck to a collet chuck or vice versa mid job.
Here's a pic I found that is pretty close to my collet chuck - I've added thread sizes.
I tried making a sleeve: 1/2-12 thread outside and M10x1.5 inside. I thought I could screw and loctite this into the top thread in the collet chuck which would let me remove the M10 drawbar through the top. Problem was not enough meat left on the sleeve and it fell apart as I tried to tap the internal M10 thread.
There's also a larger thread at the bottom end inside the collet chuck morse taper - it's 5/8-11. There might be enough meat left if I try the same idea using this....M10x1.5 inside 5/8-11.
Only problem - I have no idea what this thread is used for. Will I be preventing a normal function of the collet chuck if I screw something into this thread ?
Can anyone help ?
As always, all help is appreciated.
torch
Jun 10, 2016
2,897
1,148
Muskoka, Ont.
Are you SURE your mill has an MT3 spindle? Because the pictured toolholder sure isn't an MT3 taper. That drawing looks more like a CAT or TC type.
EDIT: Zooming in on your original photo from page 1, that does look like it could be an MT3 to ER-40 adapter pictured. If the spindle is actually MT3, then one would expect to see a slot in the spindle when the quill is extended.
Some better photos might be helpful.
Paul Allwood
Jul 8, 2025
887
1,670
Yes, it is definitely a 3MT spindle. I just used that pic to point to the 2 different threads rather than drawing my own. Yes, the spindle does have a slot to eject the flat tang at the top end of a drill chuck morse taper.
Even though it's MT3, it still seems like a good idea to use a drawbar to help lock in the collet chuck for milling. I'm just trying to make that bit a bit easier by making the drawbar removable from the top.
I'll take some more pics today.
Paul Allwood
Jul 8, 2025
887
1,670
Here's some more pics....
The collet chuck is MT3 ER40
Collet chuck drawbar thread is 1/2-12 BSW
The thread inside the collet chuck morse taper at the collet end of 5/8-11 BSW
The largest diameter that can fit through the spindle on the mill is about 11 mm, hence my plan to use high tensile M10 threaded rod for a new drawbar
The slot through the mill spindle to eject from the tang on a morse taper drill chuck without a drawbar
MT3 drill chuck that I'll probably use in the mill and the lathe
Homemade drawbar supplied with the mill
The 1/2" thread at the end of the drawbar stops it from being removed through the top of the spindle.
I want to be able to use the collet chuck and the drill chuck in the mill, but don't want to have to raise the mill head each time I need to remove the drawbar. The drill chuck won't fit with this drawbar in place.
My original plan to make and fit a sleeve with a 1/2" external thread and a M10 internal thread at the small end of the collet chuck morse taper didn't work - the sleeve broke when I tried tapping the internal thread as the was too little material left. As I type I'm wondering if it might have a better chance of working if it's screwed into a 1/2" nut when I tap the internal thread ?? Might give it a try.
The other plan was to use the same idea but using the 5/8 thread at the collet end of the collet chuck. The thing I'm worried about here is that I don't know what the 5/8 thread is there for. Will I be preventing another normal use of the collet chuck ?
Am I better off just making a better version of the drawbar that was supplied ?
Other ideas and comments always welcome.
3,594
That was my first thought - an insert in the 5/8 thread with a 10mm internal thread. Insert & drawbar hardened, of course.
The only drawback I see is that it might limit the length of parts you put in the collets.
Paul Allwood
Jul 8, 2025
887
1,670
Thanks. I had only imagined putting end mills into the collets. What else would they normally be used for ?
