Need a New Snowblower
powerkraut
Bx2230
Apr 13, 2025
39
12
Usa
The body on my BX2750D is too crapped out to keep a cutting edge attached. There's not too many local options for another one in decent shape. Does anyone know what other models I can make work without serious fab work given that I have everthing else in good condition? Worst case I'll keep running what I have to move the majority of the snow and just add a back blade to wipe the last inch off of the asphalt.
powerkraut
Bx2230
Apr 13, 2025
39
12
Usa
I was moving last week so I had the dealer pick it up to put a new cutting edge on it. They won't do it, they say the body is too thin to even weld to and it's been repaired previously. I don't get it back to look at until Wednesday, but I'm not a welder anyway. It may have been due to the old cutting edge being worn, but the bolts kept grinding off so I wanted it welded on so it was lower profile. The tractor is a bx2230, I keep seeing that the 2750 series isn't the only front mount blower that can be made to work, but I can find any specifics on what other models can work or what difficulty is involved in making them work.
mikester
M59 TLB
Oct 21, 2017
4,187
2,877
www.divergentstuff.ca
well made, jamb free round chutes, local company
powerkraut
Bx2230
Apr 13, 2025
39
12
Usa
I appreciate the link, I'm not planning on buying new and I'm trying to cast a wider net for my FB marketplace searches.
powerkraut
Bx2230
Apr 13, 2025
39
12
Usa
Hire a welder to fix it.
Or learn to weld!
I hired a welder, they said not enough left to weld on. I call bullshit because I've seen welders use tons of filler to build up just about anything, but I'm not a welder so I may be talking out of my ass. Regardless if I can't find a replacement I'm going to buy a welder and try fixing it myself.
11,543
Sounds like you got a welder with low talent / skills.
When what you need is a welder that's also a fabricator.
Yea I know, tough to find them.
BAP
Dec 31, 2012
3,219
1,325
A Location might help you get responses for snowblowers out there for sale. I see at least 3 for sale listed online within 25 miles of my location.
powerkraut
Bx2230
Apr 13, 2025
39
12
Usa
I'm in NH, that being said I'm asking if there are any other models that will fit a BX2230 outside of the 2750 to try casting a wider net. The only 2750 in 100 miles of me is pretty clapped out and not priced to sell.
@wolfman good to know I'm not just talking out of my ass then. It's just a sheet metal box, I can't imagine that it would be that hard to weld on new sheet metal, but here I am.
11,543
To answer your first question, The BX2750 is the only moddel listed as compatible.
Are other models compatible, maybe and maybe not, there are a lot of factors at play with front attachments that are mid pto powered.
BX23-S,57 A-C D-14,
6,344
post 2-3 pictures of your 'unrepairable' snowblower ! Odds are is IS totally repairable. I've yet to find anything made of steel ,with some good left in it, that I couldn't fix 'as good as new'.
Donystoy
Dec 10, 2013
750
385
Binbrook, Ontario
That is crazy! Got my mig welder/gas years ago when I was repairing rusted out car sheet metal. A heck of a lot thinner than snow blower steel.
powerkraut
Bx2230
Apr 13, 2025
39
12
Usa
I get it back Wednesday, I'm in the middle of moving but I'll post pics. Sounds like I'm going to buy a welder and try my hand at fixing it.
Alright, if there's not a known easy answer I'll leave it alone. Sounds like it's more likely I'll be able to fix what I have than cannibalize a body off of a different model.
