Moving a L2194A snow blower
Beebad
Kubota L-3560 HTC
Oct 12, 2024
97
Northern New Hampshire
Hi,
i have an L-3560 and an L2194A snowblower.
i need to move the snowblower from point a to point b .
If it isn't mounted or attached to the tractor are there attachment points used to moving it around?
Shawn T. W
Dec 9, 2024
922
1,645
SW Missouri Ozarks
I'm not familiar with that blower
... But if you have forks, set it on a pallet, strap it down and move with forks ...
RMS
Sep 26, 2021
323
717
Buckfield Maine
Some snow blowers have lifting eyes on the outer ends to attach a strap/chain to if you don't have forks.
Trustable
l2501HST
Jul 5, 2022
403
412
If you dont have forks, probably just gonna be easier to hook it up and move it. That's how I moved my snowblower. Those suckers are heavy so easier to throw it on the 3pt then put my weight barrel on the 3pt then lift it or strap it to the loader.
Workerbee
Zd21
Mar 1, 2020
401
288
MN
If you have a loader slide it under then chain the top back. Thats how I move mine in and out of storage
Beebad
Kubota L-3560 HTC
Oct 12, 2024
97
Hi,
The blower is wedged into this space. I think i will be able to wrap slings around some portion of rhe blower and use rhe forks to lift and swing it around and drag it off this area. I guess theasiest thing to do is learn how to remove the FEL and attach the blower and drive it into my heavy equipment shop.
11,549
Yea that not a simple moving a blower!
Thats moving a blower thats attached to the subframe and mount.
11,549
The Orange part is the snow blower, the Black part is the subframe and mount.
Caden
1979 B7100
Apr 16, 2026
431
251
My thought would be first to drag it out to the open a bit. Then maybe make a triangle lifting set up. One chain or strap to the subframe crossmember, the two straps each side of the blower, wrapped and clinched right around the housing. Behind the rotating shaft so you don't bend it.
Then again thats risky, if the hydraulic angle and lift on the blower moves while lifting it, that would be bad.
Might be a bad idea, and that's assuming you fel can lift the whole thing anyway.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,285
1,159
Amsterdam, NY
If you have the manual that goes with the snow blower follow the instructions and disconnect the blower (orange part) from the subframe (black part) and move them as two separate pieces. It may take a lot of effort and a helper or two. If you want to attach the subframe to the tractor in the near future I would think you'd want the blower off it anyways.
