M9540 3-Point lifting issue
Anthony9540
M9540
Nov 6, 2026
19
I have a 2007 M9540 (no front end loader). My 3-point stopped lifting under load. With nothing on it, it lifts fine, but as soon as I put a brush hog on, it will try to lift but can’t. Could this be as simple as dirty hydraulic filters, or is this a common mechanical issue?
7,483
Ir could be any number of things. Rather than guess diagnose..
Do your rear remotes work?
Do you have it in draft control mode?
Anthony9540
M9540
Nov 6, 2026
19
I believe the rear remotes work, but to be honest I don’t know. I purchased the tractor used a few years ago, and I don’t have any hydraulic implements. I ordered a gauge to check hydraulic pressure, so I’ll be able to check that when it arrives.
Regarding the draft control - I will check and get back, but I’ve tried it in every position and it still wouldn’t lift heavy implements.
it moves up/down just fine with nothing attached.
It will lift my box blade fine, but drops when the tractor is at idle or off (regardless of lever position)
It will try to lift the brush hog, but doesn’t have enough power to fully lift it - maybe a couple inches. With the brush hog barely off the ground, and the rear wheel supporting the back of the hog, I’ll drive out to the field (a few hundred yards). By the time I get out there, sometimes the the brush hog has lifted. Once I drop it to begin mowing, we’re right back to square one (doesn’t want to lift).
7,483
Thats mich better. What you are describing sounds like the 3pt lift cylinder(s) are leaking. The safety relief is another possibility. When you get your gauge check pressure at the remotes and that will guide where to go next.
Anthony9540
M9540
Nov 6, 2026
19
So I haven’t been able to test hydraulic pressure yet, I believe I don’t have the correct coupler for my remotes/gauge.
however, I did drain/replace the hydraulic oil and filters. I’ve attached a photo of what I found when I pulled the rear-most filter, and when I pulled the forward-most filter there was very little in the filter (maybe that’s expected since I drained the fluid first).
so with filter and hydraulic oil replaced, I started the tractor and I get absolutely nothing out of anything. The drawbars won’t move, and the tractor will not move forward or aft. Now what?
thanks in advance! I’m at a loss
BergyPatty37
Kubota L355-SS w/L1720 Loader
Jun 14, 2026
70
19
Maine
@Anthony9540 Came across this old thread, while not the exact same symptoms as you might be a good reference to read:
7,483
Now you go to the source and INSPECT the pump supply and discharge flows. Do you have a loader on the tractor?
Anthony9540
M9540
Nov 6, 2026
19
That is correct. I used the tractor today (still very weak 3-point - barely lifted my box blade once it got loaded with dirt). I replaced they hydraulics and filter (Kubota filters and Triax Agra UTTO Supreme GL-4 fluid). Now I have no movement at all with the 3-point or fwd/rvs with the tractor.
Anthony9540
M9540
Nov 6, 2026
19
Ok.. I don’t know who you are, but you’re good. I checked the steering. At first it was very reluctant to move, but slowly got a little easier and easier. Then I tried the 3-point - it works. Then the FWD/RVS - it works as well.
tomorrow I’ll check to see if the 3-point is any stronger. I’d love to check the pressure via the remotes, but I haven’t figured out what couplers are on the stack. There’s nothing on them to slide/lock the make coupler in place, so I’ll dig into figuring that out next.
the only other tractor I have experience with is my 1966 Ford 4000, so all this hydraulic stuff is new to me.
11,543
The pump was cavitated, it's common occurrence with older Kubotas and filer and fluid changes.
If it happens again, then it's a suction line leak or pump issue.
Do you have an Implement that uses the remotes?
If you do, pull a line off and connect the gauge to that line and test it.
11,543
Take a picture of your remote connections and someone might have an answer for you.
