M5660 3 pt lift arms adjustment
KB64
M5660 SU, L3600, Firminator, etc.
Nov 13, 2023
AL
My 3 pt arms are not going high enough to hook up to a 6’ disk. They only reach about 20”. Lift lever is very stiff.
One note is that a few months ago the left stabilizer arm got bent crossing a ditch. It was replaced but now lift arms seem to have limited travel. Thoughts ?
11,757
Do you have a copy of the WSM? Lots of information about inspecting and adjusting the 3-point linkage mechanism. You might have messed up the adjustment of the position rod and feedback rod. Does your tractor have draft control? That system has a draft rod and feedback rod too that can affect the maximum height of the lift arms.
All of this is well laid out in the WSM so I suggest that you download a copy and do some reading.
11,757
Here's the sort of information you'll find in the WSM. This is for the M6060/M7060 but the WSM for the M5660 will be similar.
Hopefully you haven't damaged something major, but making sure all of the adjustments are within spec would be a good start. Also, making sure that the 3-point components are properly installed and optimized, and that nothing "obvious" has been overlooked.
Caden
1979 B7100
Apr 16, 2026
386
225
Yeah I'm thinking the replaced stabilizer arm may not have anything to do with it, but being that the control lever is stiff I'm leaning towards a linkage/ feedback linkage issue.
