I'm replacing the couplers on our snowblower since the teeth are damaged. One coupler runs in two bearings, which I have opened up to find not much visible grease, The bearings run smoothly, but there is only a thin film of grease on them at best. I think I should re-grease then since they are off.
I think the original grease was black. I believe the 1" i.d. bearings run at 2500 rpm or so. I have no-name black bearing grease, some red and tacky, some Lucas heavy duty green, and some Kubota 3% Moly. I think the moly is not good due to reported 'slippage/skating' of the bearing balls, so I'm looking to the others as options. I can always buy something else if need be.
Any advice would be helpful. Both the lucas greases say they are for high speed bearings. I've had the Red and Tacky leak out the end of the grease gun if it sits in it for a while, which isn't inspiring.
Thanks.
I should add that these bearings are not easily serviced so longevity is a concern.
Thanks.
