Yes I've done it.Hello. Has anyone replaced their turf tires with Light truck tires? If so, how did it go?
Cost. where I live, northern WI, Walmart ( lowest cost I can find) has a direct replacement turf tire for $350 each, only 4 ply. A LT mud tire, 6 ply, is $170 each. If I chose to go with R4’s or R14t’s, no 15” wheel sizes in those, so I need to buy new wheels at $350 each. with mounting, turf would be near $800.00. Switching to R14t, would near $1300( with new wheels to do it). I can have 6 ply mud LT (15”) mounted on the wheels I have about $400.Why do you want to do that?
Yes , thanks, rolling circumference is the same. 33x12.5 -15 for my rear. LT is sameYes I've done it.
You have to make sure the rolling circumfance is right or you'll damage the front drive train.
How has it been going ?Yes , thanks, rolling circumference is the same. 33x12.5 -15 for my rear. LT is same
Cool, I can’t find but 1 video on Youtube , that one worked out great.I've seen it done a lot.
Not so much in canada but regularly see it when I used to work in india. There a lot of the field work was done by hand and tractors pretty much stayed on hard top roads pulling trailers so traction and big lugs in the dirt wasn't an issue.
