Low hours. Change the oil anyway?
chris142
B7510
Jan 4, 2026
87
49
Apple valley,ca
Coming up on 1 year on my last oil change. Shell 5w40 and a wix filter. Should I change it even with only 26 hrs on the oil and filter? Seems like a no brainer for $30 or so.
L35
Jun 13, 2010
727
838
CT
I’m similar and go 2 years but I’m not under warranty.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,254
1,135
Amsterdam, NY
No harm in doing it early.
If you only have 26 hrs on the tractor - not sure how much white stuff you get in Apple Valley but if you're planning on moving snow this season you might want to do the complete 50 hr. service early while your at it before winter sets in. I would, but that's just me.
chris142
B7510
Jan 4, 2026
87
49
Apple valley,ca
White stuff? Like snow? In the Mojave desert? My wife watches those hallmark movies and its always snowing in those places.
Drove to work this morning with the ac on.
Tractor has more hours than 26 it has 26 on this oil change. I'll probably change it yearly so I can sleep well.
Bee-Positive
Nov 16, 2022
1,254
1,135
Amsterdam, NY
Wasn't sure where you were. :p I change my engine oil and filter every two year just because.
Here's a picture of Northeastern winter tumble weeds. The wind blows so hard it make it's own snowballs. o_O
4,289
Just run it once and awhile and get it fully warmed up to burn off any condensation.
Change when you hit 50 hours.
No worries!
Good Luck!
If it isn’t started…. there won’t Be any condensation.
I’m always perplexed to hear someone say they‘ll start some engine that has been sitting for months and “run it until it gets warm”… to “keep it oiled”…. etc etc.
That’s about the worst thing you can do, IMO. Starting it up…getting it “warm” places the majority of Wear on the machine….and creates the most water vapor ….which remains in that engine….. .for it to be shut down, prior-to…. or instead-of, .. doing an hour or more of “real work”.
A similar (to me nonsensical) thing is hearing someone say that… before they actual “start” an engine that has been sitting awhile….OR… before starting an engine that is in “arctic” cold-conditions…. They’ll “motor” it with the starter until oil pressure is built up…THEN actually allow it to be started/run.
WHY ? I wonder…. does that wear-and-tear on a starter motor and battery…. be any easier on the engine than simply starting it and allowing it to build oil-pressure much quicker... ??
All the bearings, rings, cylinders, valves, etc are being rotated and moved MORE CYCLES …than if they’d simply Started it and Let it Run normally. :rolleyes:
number two
B3030HSDC L2501HST
Mar 26, 2021
433
206
Northern Lower Michigan
Shame on me!
I didn't explain well enough.
Thinking the OP still used the tractor on occasion,I stated to be sure to warm it fully occasionally.
Thanks for pointing out my error!
4,289
Shame on me!
Perhaps I mis-read it. Kind regards….
chris142
B7510
Jan 4, 2026
87
49
Apple valley,ca
Shame on me!
Ya I used it about 2 hrs non stop today @2000-2600 rpm so it got fully warmed up.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
3,000
2,372
Western MT
Buy a Kubota filter, and Rotella or Kubota oil and change it.
4,289
Good luck finding the Rotella viscosity you prefer. I’ve used nothing but T6 in 5W40. since my new ‘24 Ram w/Cummins …. and now cannot find it anywhere. I’m switching to Valvoline (which I’m told is Cummins factory-fill also.)
(Damn. I‘ve finally participated in a “which oil?” discussion.). 🤡
jimh406
Jan 29, 2021
3,000
2,372
Western MT
It's available on Amazon.
BX23-S,57 A-C D-14,
6,331
Sounds like you'll spend more time changing the oil than running it in a month..... Curious as to why so little 'seat time'.
I never changed oil in one of my tractors for 15 years, only got 1hr at this time to put giant pumpkin onto a trailer.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,394
913
under a rock
Yep
I know guys who do that with motorcycles.... start it up in the dead of winter and let it run in the garage for 10 minutes then shut it down....
or rev the piss out of it... 🤡
I don't start anything unless I'm going to use it/ride it properly. (full operating temperature)
John T
May 5, 2017
1,394
913
under a rock
seems like you made up your own mind. Why even ask?
26 hours? I wouldn't touch a thing. I'd spend the $30 on a good bottle of Tequila instead. :devilish:
4,289
Trash Panda
L2501
Feb 18, 2022
303
284
Wyoming
FWIW, I’ve been told by multiple guys who work for Cummins that the 6.7’s come from the factory filled with Valvoline PB 5w-40.
4,289
Like so many things these days….. Valvoline, formerly a U.S. firm, is now owned by …. Aramco.
Trash Panda
L2501
Feb 18, 2022
303
284
Wyoming
I mean, if you’re hung up on needing to run an oil produced by a company owned domestically, there are far better options out there than the basic rotella/delo, but it’s gonna cost.
If you want cheap, be prepared for it to come from a global conglomerate. It’s the sad reality
