L4701 Weep Hole Leaks
KevL4701
2020 Kabota L4701
Nov 12, 2026
WI
I am new to the group and owner of a 2020 L4701 with 940+/- hours. I have had issues with the weep hole pin under the tractor leaking trans fluid. It is supposed to be a dry chamber and the weep hole is only to allow water/condensation to drain out. Has anyone out there had ongoing issues with hydraulic fluid dripping from the weep hole? I have had the four wheel drive input seals replaced but still have the issue.
Thanks
7,484
Thanks
Likely transmission input or output shaft seal leak. How bad is the leak - little damp spots or puddles??
whitetiger
Nov 20, 2011
3,851
2,243
Kansas City, KS
Was the front axle input shaft seal replaced, or were the front axle output shaft seals replaced, which requires the tractor to be separated to access? The input shaft seal is actually in the front axle housing.
I assume you are saying the front axle drive output shaft seals were replaced. If that is the case, surely they also replaced the transmission input shaft seals, and the gasket was replaced while it was separated.
KevL4701
2020 Kabota L4701
Nov 12, 2026
WI
Thanks
Have had the tractor split and seals replaced multiple times now and it started leaking again.
KevL4701
2020 Kabota L4701
Nov 12, 2026
WI
I know the four wheel drive seals were replaced. I have had it in multiple times and it has been split multiple times to have seals replaced. Thanks for the input.
11,555
I would say then either they didn't install the right seals, or they didn't install the seals right.
Are you 100% sure it's hydraulic fluid and not motor oil?
whitetiger
Nov 20, 2011
3,851
2,243
Kansas City, KS
It is also possible for the fluid in the front axle to leak around the axle input shaft seal, run through the front axle drive shaft cover tube, and leak onto the ground from the weep hole.
