L3560 PTO freewheels while disengaged
red ryder
L3560 GST
Sep 26, 2026
Louisiana
I have a 2016 L3560 GST and the PTO turns while the engine is running and the PTO is disengaged. When I want to connect my bush hog I have to shut the engine off. With that amount of drag the PTO does not turn until engaged. I am the second owner and the previous owner split the tractor and replaced the clutch. Not sure if that has anything to do with it but fyi. Thanks in advance for any info.
JailBreak Your Tractor
Vendor Member
BX25D
Nov 26, 2024
45
35
Ozarks
Does it still spin once it's fully warmed up, or mostly on cold starts? The PTO clutch runs in oil, so some drag with cold, thick oil is common and usually goes away as it warms. If it still turns with no load once it's warm, I'd check the PTO lever/valve linkage and the PTO brake before blaming the new clutch. Since it was split, it's worth confirming everything on the PTO control side got hooked back up and adjusted the same as before.
JasonW
931
636
Al
It’s a good idea to have the engine off anytime the PTO is being hooked up or unhooked.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,121
2,542
WestTn/NoMs
As Jason said, turn the engine off when working around the PTO.
The PTO clutch is hydraulic and has a brake which engages when pressure is removed from the clutch. You could check the pressure on the clutch to see if residual pressure is partially engaging the clutch.
11,546
You PTO clutch has, or I should say had a brake.
Sounds like the previous owner didn't repair it properly.
You really should get it fixed!
whitetiger
Nov 20, 2011
3,851
2,243
Kansas City, KS
Was the PTO clutch replaced, or was it the main clutch on the engine's flywheel that was replaced?
The PTO shaft on L3560 should never, under any circumstances, turn with the PTO in the OFF position.
If it is turning in the OFF position, there is a PTO brake problem, or the disks are warped or not assembled correctly.
If someone has been into the PTO clutch before, it could be due to incorrect assembly or damage from misuse or failure.
red ryder
L3560 GST
Sep 26, 2026
Louisiana
red ryder
L3560 GST
Sep 26, 2026
Louisiana
It was the main clutch on the engine flywheel that was replaced.
The PTO engagement is electric on this tractor.
11,546
Technically the PTO clutch is Hydraulically engaged.
The electric operates the Valve. ;)
So you're going to need to do a split and repair the PTO clutch.
whitetiger
Nov 20, 2011
3,851
2,243
Kansas City, KS
I do have some knowledge of the mechanicals within those tractors. :)
