L2800 KNOCKING/SMOKING
DATA
KUBOTA L2800
Nov 7, 2026
LONGVIEW TX
Was mowing then Kubota L2800 began knocking & smoking from exhaust. Turned off & towed back to house. It will turn over. What now? Always before the holidays! Blah!
11,449
Stick your nose in the fuel tank, does it smell like gasoline?
11,449
fuel tank will always smell diesel. Maybe headgasket or.....?
It won't smell like diesel if even a small amount of gasoline was added.
If you won't go check it then how do you know for sure?
You description is screaming contaminated fuel.
Have you checked changed the fuel filter?
Have you checked for water?
No it's not a head gasket issue.
11,449
Let me clarify:
A Diesel tank will not smell like Diesel if any gasoline was introduced into it.
It will smell like gasoline.
Water in the fuel can also cause it to cough / knock and smoke.
