l245dt 5 post igniton switch wiring
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,285
1,159
Amsterdam, NY
Hey jim fifield, welcome aboard!
Try this thread, it may or may not be there, I didn't look. If it's not maybe someone here has a copy.
3,198
You should mark the wires and where they connect to the key switch before removing the wires for ease of connection.
I believe that your new OEM key switch will have 6 posts out but two will be shorted to each other (according to picture on Messick’s). I also saw some markings on the switch on the black plastic back that are the same markings as the schematic above.
From memory on my L185 replacing the switch was pretty easy since the wires were not long enough to move around much and the key switch is keyed to the dashboard so can only be installed in one position. And some posts will have two wires connected (I think).
For reference L1 and L2 go out to the head lights, IG goes to the fuse block and also to the rocker switch, T goes to the tachometer light bulb and some rear lights, R goes to the starter/positive battery cable.
jim fifield
l245dt
Nov 18, 2026
Lebanon or
I need wiring diagram for l245dt 5 post ignition switch
jim fifield
l245dt
Nov 18, 2026
Lebanon or
R Thank you. You talked me though it knowing where the wires come from I traced them and got it right.You saved me a lot of time
