L1720 / L345dt Loader Operation Troubleshooting Help
evantwheeler
L305dt, L345dt x3
Apr 19, 2023
51
26
Menifee, CA
You are wasting time swaping parts. Your lack of function is not caused by bad cylinders. Something is wrong with the plumbing. Test the circuits!
By test the circuits, I assume you mean pressure test?
Looking at parts on SurplusCenter.com to put together pressure gauge assemblies that I can plumb inline and curious how many I should build & install. I assume I want one on the "in" side of the valve, one on the "out" and one each on the A & B ports if I want to test out the lift cylinder circuit?
7,387
I am talking about testing flows in and out of the ports in response to movements of the control vakve.
A pressure gauge is a helpful tool but you can do the basics without it. You only need one gauge with a hose and fittings to allow you to connect it to different places in the circuits.
