Kubota MX6000 - what is this control stop for?
kba293
Kubota MX6000, Woods BB72.50 cutter, Virnig grapple bucket, Meteor snowblower
Jun 8, 2026
Wisconsin
I have a small metal plate and bolt on the rear 3PH position control lever of my Kubota MX6000.
It's appearance is similar to a "stop", to prevent the lever from moving past a certain point. However, it is not adjustable. The bolt threads into this one fixed position only.
Photo attached.
What is it's function?
JailBreak Your Tractor
Vendor Member
BX25D
Nov 26, 2024
45
35
Ozarks
That's the position control lever stopper. It keeps the lever from going all the way to the top of the slot, so when you raise the 3-point the lift stops just short of max travel instead of sitting against the relief valve and heating the oil. It isn't meant to be adjustable, which is why it only bolts in one spot. The only time it normally comes off is for a relief pressure check: the service manual has you remove the stopper, put a gauge on the lift cylinder test port, run the lever all the way up at full throttle with warm oil and read the gauge, then put the stopper back on tight. I'd leave it in place for normal use.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,246
1,225
E.
I will challenge you and disagree. It is moveable.
it has a lot of uses?
- on some smaller B's that "lock" is reloated to make sure the 3pt lever is kept in the full down position if/when a backhoe is attached. Damage can be done if 3pt raised when backhoe hooked up.
- for equipment like tall topped logging winches especially with safety screens installed or close in snowblowers with tall chutes the stop will prevent the operator from lifting 3pt to high which could cause contact of equipment to rop's or cab making equipment or tractor damage.
many may find that stop of no use. Many will find it priceless.
MapleLeafFarmer
Dec 2, 2019
1,246
1,225
E.
No, it is not moveable.
There is a moveable/adjustable stop ahead of the 3PH position lever. This one, behind the 3PH position lever, is not.
Thank you @JailBreak Your Tractor for the explanation.
ok... I will give a little more detail to help out.
I think its a 10mm socket will work but going off top of mind so size might be wrong
  1. you remove bolt 100 from its resting / retaining point.
  2. this loosens the stopper labeled #80
  3. you then move the stopper down the lever channel either on the low side or high side of the lever depending on if you want to stop the amount of rise or fall of the 3 point hitch.
  4. put the #100 bolt through the stopper #80 and secure in place with a backing washer / bolt. In my experience kubota does not supply this backing bolt / washer but its generic and you can get from many sources.
  5. the stop is now relocated from its resting / storage position ready for use in the lever channel if the operator wants the stop to be placed "in play". Its a choice the owner / operator gets to make on whether to have in the channel ready to use or "locked and stored" out of the way.
  6. what i do is recycle that bolt #100 and replace with a nifty 3 sided knob you can buy from Kubota parts so you can tighten/loosen by hand on the fly and then get function to move the #80 stop by hand while seated and without any tools in the field.
Its the owners / operators choice whether they want the stop locked out of the way of the full channel movement or placed in play below the lever to limit implement drop or above the lever to limit implement rise. Kubota can't guess how or even if the operator wants to utilize the stop function as many never use, some may want to limit down while some may want to limit movement up.
Vendor Member
BX25D
Nov 26, 2024
45
35
Ozarks
Good info @MapleLeafFarmer, and that's a handy trick. Moving the stopper into the lever channel and swapping the bolt for a knob is a smart way to set a limit on the fly out in the field, especially with a backhoe or a tall implement on.
The original question was what the part does the way Kubota designed it, though. From the factory it's the position control lever stopper, bolted in one spot to keep the lift from running all the way up against the relief valve. Making it work as an adjustable stop is a good hack, but that's a different thing than Kubota designing it to be adjustable.
MapleLeafFarmer
Dec 2, 2019
1,246
1,225
E.
here is a couple pic of the oem knob Kubota sells when you want the stop to come off its resting position into play. This open cab has it in the max. limit down position. Some may require the tab to be bent depending on model etc..
I think the first pic is a MX open cab and second is a B?
If you don't want to use the one that comes with the tractor I have seen guys that use one on both sides of the lever to limit down / up and as JBYT says to protect max. lift..
cheers
