Kubota Lawn Tractor T2080 Hydrostatic Drive operation
ljvp
Kubobta T-2080, Kubota GST2550, JD SST18
Apr 25, 2026
Oregon
Both rear wheels have a drive shaft to the Hydro drive. However when the tractor is driven on uneven grown only the left wheel provides power. I must push the machine to more level ground to distribute the wheel load more evenly. I would expect the Hydro drive to compensate for such situation. Is this normal? What am I missing?
edritchey
2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75, Landmaster L5W UTV
Jul 19, 2014
1,198
978
Wellsville, PA
May have a sheared keyway on the one that's not turning
11,473
While it has a hydrostatic transmission it still only has an open differential.
So what your experiencing could be normal.
Lift the back wheels off the ground turn one wheel one direction the other wheel should turn the opposite direction.
If either doesn't turn like that it's got an internal issue.
