Hi everyone,
I am working on a Kubota L1-235 tractor with the D1462 engine.
I recently acquired a set of genuine Nippon Denso injectors (bodies marked 4540 / 12L) fitted with original DN0PD80 nozzles.
Previously, I was using aftermarket Chinese DN0PD55 nozzles, but I’ve been having stability and Weeping/dripping issues on the bench test with those cheap alternatives.
From my technical checks, both DN0PD55 and DN0PD80 share identical outer dimensions, body fitment, nose/pintle geometry, and a 0-degree axial spray pattern. My understanding is that the 80 suffix indicates a slightly higher flow capacity and minor internal pintle profile variation compared to the 55.
Before installing them, I would like to double-check with experienced Kubota mechanics:
- Is DN0PD80 fully compatible and safe to run long-term on the D1462 engine at standard pop pressure (around 145-150 bar)?
- Has anyone run Denso DN0PD80 in place of DN0PD55 on this 23HP engine series?
