Intermittent start
red ryder
L3560 GST
Sep 26, 2026
Louisiana
I have a 2016 L3560GST and twice now in the last week it has failed to even make a click sound when turning the key to the start position. I tapped on the starter with a screwdriver handle and it started on both occasions. Curious if there is a solenoid on the starter that may be sticking and could be replaced or is that all built into the starter and I have to replace the starter assy? Thanks for any help.
Workerbee
Zd21
Mar 1, 2020
401
288
MN
Yes theres a solenoid on your starter. Strange that you didnt see it when tapping on the starter. Being that it goes after tapping, I’d suspect your brushes are hanging up. Pull the starter, disassemble, clean and lubricate it.
pigdoc
G1800S L2500
Aug 19, 2022
419
362
SE Pennsylvania
Ya, I have had that problem intermittently. More likely when the tractor has been sitting unused for some time. Probably some mild corrosion hanging up the solenoid action. But, check the neutral safety switch on the H/L lever (or the equivalent on your newer tractor). Sometimes you can hold the key in the Start position and wiggle the H/L lever to find the switch contacts.
Also, I found another glitch in my 2500's starting circuit that's been vexing me for a couple of years.
Once in a great while, with a freshly charged battery (13.2 volts), when I twist the key, the solenoid will activate, but the tractor won't crank. Aggravating. Last time I started it, I happened to turn the steering wheel about 20 degrees while the key was in the Start position, and it commenced cranking! So, there must be a high-tension short under the dash, near the steering shaft. I need to disassemble that area to install a new fuel system (filters and sediment bowl) so I'll roll that little detour into the job. That's pretty close to the top of the to-do list right now...
-Paul
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
499
588
NE Ohio
(y)
Workerbee got it!
Three potentials: 1; Solenoid is stuck due to corrosion; 2. wire on solenoid is loose/corroded; 3. brushes or commutator in starter are corroded.
Disassembly and cleaning will take care of all three.
