I bought one!
A Fish Bud
MX4900
Oct 12, 2026
Ontario, Canada
Well, after many, many, many sleepless nights researching, watching, reading and comparing, I finally bit the bullet. Big thanks to this forum for helping me choose - There's lots of great information here.
We just got 20 acres of completely overrun bush and have big plans to work it. We want to have some gardens, plant some food, clear areas for outbuildings/sheds, process our own firewood, have trails throughout the property, and create a space wildlife enjoys. Currently it's so overgrown you seldom see animals except for racoons. The deer all but skirt it because it's SO thick and thorny.
We purchased a MX4900, and take delivery at the end of the month. I don't really have a goal with this post, I'm just kind of opening a conversation about what we got, and any helpful hints/tips/tricks for good ownership habits from day 1. We are new to tractor ownership and are totally open to helpful comment. My father owned a BX25-something-or-other and I have years of use on that thing but that was a long time ago and I wasn't the owner so I just used the thing - He took care of it. We wanted to buy local, so most of our attachments are made within 1-2 hours of here, in Ontario.
With our tractor we purchased;
Quick Hitch - QH20
Wallenstein Chipper (made local)- https://www.wallensteinequipment.com/in/en/model/bx52r
AgroTrend 7378 (made local) - https://www.agrotrend.ca/copy-3-of-1000-2000-series
HLA RRG66 Rote Rake (made local) - https://hlaattachments.com/item.php?prod=112
Mapleside 7ft Box Blade (made locally) - https://www.maplesidemfg.ca/products/grader-box-blades/3-point-hitch-land-plane-7ft
Mapleside 5500lb forks (made locally) - https://www.maplesidemfg.ca/products/pallet-forks/5500lb-pallet-fork-ss-q-tach
I hope I got an ok deal on the thing. Got them to extend 0 percent from 60mnths, to 72 (inclusive of ALL attachments, including 3rd party.) Free was:
Right-handle door kit
Rod-level indicator
Arm rest kit
Delivery 2 hours away
Hydraulic top-link
Workshop manual
Filled tires
First service kit
Again, no real ppurpose to the post. Just postin'!
Reactions: 9 users
3,102
I understand your excitement - sounds like xmas in November!!!
Where I am a BXer kinda guy - I have a great appreciation for the big boys in the K lineup.
YOU know the rules ........... Pictures are a must, make sure you take several - OR otherwise it never happened!!!! :ROFLMAO:
Congratulations!
4,304
Did you specify What-Liquid will be used to fill/load the tires?
A Fish Bud
MX4900
Oct 12, 2026
Ontario, Canada
Congratulations!
Thanks buddy! Yeah I will for sure, should be here by end of month!
JasonW
918
619
Al
Congrats. Start with reading the owners manual fully and if there is something in it that you are not sure of, try researching it first, and if all else ask here.
A Fish Bud
MX4900
Oct 12, 2026
Ontario, Canada
Yeah I managed to get the Workshop/Service Manual. Pretty much a must-have for me with my toys!
Shawn T. W
Dec 9, 2024
910
1,637
SW Missouri Ozarks
Congratulations 👏 on your new addiction! 😀
Do you have any pictures of the land you plan to tame?
How thick is the "brush" as in diameter of the "stem/trunk"? ...
I see you list a grapple which can rip up some brush, but not likely to "maintain" any area's of brush from springing back up ... And there are faster options to just drive over and chew it all up!
A brush hog or flail mower can do a great job depending on the rated capacity of course, probably up to 3" diameter with that size of tractor ...
GrumpyFarmer
5,304
Haha, generally speaking I'm good at this ;) Great tip! I did get the kubota insurance so apparently that'd be 250+tax! We'll see if/when the day comes though.... insurance.....
I maybe slightly biased towards an MX😉. That being said I would offer that mine was about helpless without ballast when trying to use the loader. And first time I unloaded an implement I lifted a tire. That machine can do a lot but it is also front heavy until it’s ballasted. JMHO.
based on what you described above it sounds like you are going to have a lot of fun on your new machine and I think it will be very useful for you within its intended capabilities. MX is a great machine…did I mention I might be biased?😉
Go as slow as possible and as fast as necessary.
now let’s see some pics?!
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,438
1,043
Minnesota
Suggest you sit down and read the manual. Then go sit on the tractor, read the manual again, locate all parts in the manual. This will help when things don’t work and your here asking questions. That’s a beast of a tractor. Congrats and enjoy. Take it slow until your comfortable with its abilities. Rear ballast will be your friend. You will understand this when your rear tires come off the ground lifting something heavy and your arse puckers up. Gets your attention real quick. Good luck.
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
197
412
NW Arkansas
Well done sir—good choice going with the bigger machine. Congratulations!
fmgsr
Kubota, LX2620 - Kubota BX2380 (retired)
Dec 19, 2018
104
51
PA
That really sounds great. Good Luck & Enjoy
7,744
Sounds like a lot of toys at one time! What are you going to use first? Sounds like you need a barn for sheltering it.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
594
343
Mandeville Louisiana
A snow blower on overgrown land, I'd be curious on how that works. Did the dealer give you the third function kit for the grapple? D2Cat is absolutely correct about needing a shop/barn/ shelter, that's a lot of equipment (big investment). One week of a forestry mower with the right operator would create fence rows, trails, define roads, house pad area, out buildings, etc. Make sure your father is ready to maintain your toys. Good luck
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,757
4,666
PEI Canada
Congratulations on the tractor and attachments. That grapple is pretty heavy even for a MX.
JailBreak Your Tractor
Vendor Member
BX25D
Nov 26, 2024
35
27
Ozarks
Congrats. A few day-one habits that pay off: do the first (break-in) service on time; check the owner's manual for the hours, and don't skip the transmission/hydraulic filter on that first one. Grease the loader and 3-point pivots before you start, and often while you're clearing brush. Check hydraulic oil level with the loader down and the 3-point lowered, on level ground. Get rear ballast sorted before the first big grapple lift. With a heavy grapple on, the MX gets light in the rear quickly. Make sure the third function is installed and working before delivery day, and ask the dealer to show you how the couplers and the grapple circuit work. Enjoy it. 20 acres of brush will keep it busy.
Jailbreak Your Tractor
