Hydraulic Quick Disconnect Couplers 101
7,487
The community is awash in conflicting and in many instances flat out inaccurate information about agricultural quick connect couplers. This post is offered as a primer for the three most common coupler standards.
This is not my opinion - it is a summary of the ISO 5675 and ISO 7241 parts A and B standards documents themselves. The documents are quite short and easily understood by the average reader. However they are copyrighted and ISO controls the distribution. They are not easy to obtain outside of purchase from the ISO online store. So lets have a look inside my copies - the real skinny as my Navy colleagues liked to say. If you already know this you can stop reading right now.
General
All three standards define the physical coupling interface in terms of the male half of the coupler pair. The design and operation of the female half is left to the manufacturer and varies greatly across brands. Regardless of the design all conforming female couplers must fully interoperate with all conforming male tips.
ISO 5675 Couplers
This standard formalizes the dimensional and operational requirements for couplers historically marketed in the United States as Pioneer style agricultural couplers.
  • This standard only applies to 1/2" and 3/4" (12.5mm and 19mm) body sizes.
  • The dimensional requirements are actually defined by and identical to ISO 7241 Series A which is incorporated by reference
  • This standard includes requirements for operating force and spillage limits during connect and disconnect operation.
  • This standard also includes requirements for the front, rear, and side mounting zones on agricultural tractors
  • This standard does not define the shape of the valve poppet but conical is preferred. If a spherical poppet is used conforming male and female halves must interoperate in any combination.
ISO 7241 Series A Couplers
This standard formalizes dimensional and operational requirements for general purpose agricultural couplers commonly used outside the United States.
  • This standard applies to a range of body sizes from 1/4" to 2-1/2" (6.3mm to 53mm).
  • This standard defines requirements for operating force and spillage during connect and disconnect operation.
  • Conical valve poppets are preferred but spherical is allowed and coupler halves must interoperate in all combinations
  • ISO 7241 Series A has been fully harmonized with the ISO 5675 dimensional and operational requirements for 12.5 and 19mm body sizes. It is the sole defining document for ISO 5675 dimemensional data.
ISO 7241 Series B Couplers
This standard formalizes the dimensional and operational requirements for general purpose couplers commonly used in industrial applications. It applies to the same body size range as Series A couplers but the physical interface is different. Series A and Series B couplers do not interoperate in any body size.
HTH,
