I agree with that -- the default setting should be e-mail notification of replies to any thread you've posted to.
I also agree with that. I'm just not so sure a bunch of stickies will solve it. One sticky maybe: "How to ask for help". We'll start with your opening line:
"Complicated problems cannot be solved by long distance without complete details."
Now let's provide some basic education in asking for help. Here are some suggestions to get it started. Feel free to add more:
Provide the complete model information. "Grandpa's old tractor" doesn't tell us much. "Second generation B7100D with 6 bolt front rims, 4-wheel drive and HST" tells us which service manual to reach for.
Tell us complete and accurate details. "Won't start" covers a lot of ground. Narrow it down! EG: "I set the throttle lever to about 1/2 throttle and turn the key to the left for 20 seconds until the glow plug indicator is red. Then I push in the clutch pedal and turn the key to the right. The starter motor cranks the engine over and I see white puffs of smoke from the exhaust but the motor doesn't start."
History is important: "It was running when Grandpa parked it." lacks context. "It was running fine when Grandpa pulled it into the barn yesterday." is different from "It was running before Grandpa ran out of fuel and left it behind the hedgerow in the back field twenty years ago."
What have you tried already? "My buddy came over with his meter and checked it over." doesn't cut the mustard. "My buddy came over, cleaned the terminals and installed a freshly charged battery. He found 10.5 volts to the glow plugs when the key is turned to the left." tells us exactly what was checked and the results of the test.
"Remember the quality of your question directly affects the quality of your answer."
Great minds think alike torch and D2cat, your recommendations are spot on. As for whether "a bunch of stickies will solve it" , 3 for starters will imo go a l-o-n-g way, the one yall are talking about being the most important. Two specifically addressing these would cover 75% of newbie inquires AND be educational to old codgers like myself in case they have trouble in the future "click no start", turns over normally but not starting.
What I'm proposing with these two is step by step with multi-meter,recording results as they are done. #1. Test battery voltage, anything less than 12.? , charge battery then retest. If still below 12.? battery is defective. Then right on down the line.
We should talk about the pachyderm in the room. This move would impact what a few retired folks look forward to and enjoy on a daily basis. To these folks I say, try gaining a position on the committee to fill out the time. Also freeing up a little time otherwise spent online, can be spent taking the walk we often ignore but is so important to older people's health. So you see my round bellied friend I'm just trying to keep you around a bit longer, not spoil your fun. For those who are on their exercise bike while on YT, you will be able to share more of your gardening expertise and life experiences with us over on off-topic.
If and when this proves successful, I another idea that might be a hit. A second committee that works out and presents class for xx minutes once per week on advanced use of a particular tool,proceedure or such. It would do some of us good to swallow our pride and open our mind to polishing up on a thing or two.
I yield the floor to other esteemed members.
.What say yall?
I can see stickies being worked out by select committee behind the scene via PM and email.
