Electrical question, B2650
PHPaul
Apr 2, 2015
1,319
1,659
Downeast Maine
www.eastovershoe.com
I checked the WSM but didn't see a direct answer. What is the max output of the alternator on the B2650?
I ask because I'm contemplating running a 2Kw inverter (not at full load, but probably 1500 watts) and I have doubts as to whether the alternator is up to it.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,274
1,156
Amsterdam, NY
I believe they are 60 amps according to K-Pad.
1500 watts / 90% inverter eff / 12 volts = 139 amps.
Seems awful ambitious.
JasonW
914
618
Al
What model is yours? I’m seeing 14-16 amps for the ROPS dynamo and 40 amp for the Cab alternator model.
What are you thinking of running with the inverter?
Bee-Positive
Nov 16, 2022
1,274
1,156
Amsterdam, NY
I was off a little, the replacement for the B2650HSDC I was looking at is 55 amps.
JasonW
914
618
Al
I was hoping to run a corded leaf vac. Not gonna happen. Back to finding a lawn sweeper I guess.
I’m not familiar with a leaf vacuum, although another idea, just put a small inverter generator on a carryall or similar.
PHPaul
Apr 2, 2015
1,319
1,659
Downeast Maine
Certainly an option, but an expensive one.
The only reason I'm even remotely interested in gathering the leaves is to compost them. Appearance is not an issue. Every leaf on the place might make a 5 gallon bucketful of compost, so the choices are do it on the cheap, or don't do it at all.
JasonW
914
618
Al
Yes it helps if you already have one.
One year I gathered leaves because I got behind cutting them up as they fell, I just used my zero turn to blow them in several piles and then got them by hand onto a tarp or trailer.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,095
2,526
WestTn/NoMs
Your other post started out at the patio. Surely you have an outlet available nearby. Sounds like the scope has crept, longer cord? 🫣
PHPaul
Apr 2, 2015
1,319
1,659
Downeast Maine
The original reason for investing in a leaf vacuum was this monster Maple in the corner between the house and garage. It's now gone due to age and rot. The only leaf-producing trees now are 200+ feet from the nearest outlet so extension cords are impractical.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,095
2,526
WestTn/NoMs
Coming from down here south of the M-D, I'd say you have 3 options:
1 Mulch them with your mower and let them compost in place. This is what most people around me do, who don't have a lot of trees.
2 Lawn vacuum - seems like a big expenditure for not many leaves, especially since you're not after appearance.
3 Blower/vac - 2-stroke or battery powered might be practical if the leaves collect into smaller areas like flowerbeds. Impractical to vacuum the whole yard.
