I am an automotive tool & die maker, I use these every day, sometimes an entire shift, all of mine are dotco and Ingersoll brand.Looking at getting a die grinder for projects at our farm. Could have used one this past week instead of using a rat-tail file by hand. Never had a die grinder and my dad never had one either so I'm not sure where to start. Thanks for any suggestions.
Brands ?
Models ?
Corded vs Battery ?
Straight vs Right angle ?
Your main concern right now is how it will be powered (pneumatic, battery, corded). Will you be mainly using this in your shop area where you can use an air line, or do you need it remotely? If it's in your shop I recommend a pneumatic. If it's used remotely then a battery. I've used inexpensive grinders and they work well, all die grinders rely on rpm not hp to do their job. You'll want an A size which is sort of the standard.
Now you'll need burrs (rotary files). You'll need 1/4" shank with a 1/2" dia head for most projects.
If you're grinding on aluminum, have a container of kerosene to dip the burr into frequently, this will prevent the burr from instantly clogging. Steel you need no lubricant.
I have pics of everything mentioned. The cheap grinder has one accessory that I particularly like (an 1/8" collet for intricate work, but you'll need 1/8" shank burrs for that). You can buy an 1/8" collet for the Ingersoll grinder too.
Note one Ingersoll has a front exhaust which i like unless I'm grinding in a cavity (it then blows chips back in your face). The rear exhaust isn't bad but the chips don't get controlled and blown away from you. This will be your choice.
