Convertible Kubotas?
OntheRidge
Nov 1, 2020
512
597
Ouch!!
  • Sad
Scm
BX23S
Sep 28, 2024
464
430
Missouri
If he went through at full speed I may of felt bad. But, he obviously knew something wasn't right and kept going.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
3,012
2,376
Western MT
There is a very low overpass in one Montana town. They take out a lot of RV roofs, etc. I don't know why they just don't make it a bit higher. In this case, it's only about a foot shorter than normal 13'6". Why?
timber and wine
L4802, loader, forks
Nov 1, 2026
41
35
NE WI
They are almost all railroad overpasses. I'm not sure what the limit is on the approach grade for rails but raising one a foot probably has far reaching effects and would get very pricey. Usually they lower the road.
There are dozens of them around the country. I'm pretty sure they are all nicknamed "the can opener". I believe there is a website out there dedicated to all the "decapitations".
There is at least one I've seen with a substantial warning sign set to the same height that says in large reflective letters " if you hit this you will hit the bridge". . the bridge still gets hit a few times a year 😂😂
11,541
Yea raising the rails is not a practical option and lowering the road just becomes a lake.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
621
649
Lake Almanor, Ca
That there is some serious stupid. what…ten minutes to go around OVER the tracks in another part of town? Impatiently causing problems for others…cause if that was his he wouldn’t done that crap.
11,541
I'm betting if he is / was an employee his next stop was the unemployment line.
BX23-S,57 A-C D-14,
6,343
looked like he almost made it... lowering tractor and maybe trailer tires would have made it.
local RR bridge is 4M tall, was less in 1967 when THREE semis in one week hit it. City then lowered the road( real easy...) To raise the bridge would have cost MILLIONS,both in physical works AND loss of choo choo track for MONTHS.
6,971
It’s a railroad bridge. Was probably there decades before anything resembling a modern road vehicle existed. Road was likely a wagon track when the bridge was built.
If there are viable alternative routes compatible with large vehicles, lowering the road or raising the bridge is often not reasonable.
Edit: Re-read your post. I don’t know about the one in Montana you reference. Most of the ones I’ve seen, including the one in the video, are railroad bridges.
jimh406
Jan 29, 2021
3,012
2,376
Western MT
Fwiw, it is a railroad bridge. I don't know what the stats are, but maybe only a few people per year hit it.
