Hi - My 12v outlet stopped working. Confirmed with a meter that there is no voltage between the "button" on the bottom of the plug and the wall of the plug. Verified the fuse is good. All checks were done with the key ON.
Next step is to pull the outlet itself out to check the connections on the back but can't figure out what's retaining it. Can barely see behind the fender let alone get a hand back there. Tried gently prying around the front flange but that didn't seem like the intended way to unlatch.
Anybody ever been through this on a BX or similar?
Thank you for any suggestions!
