BX1500 Help troubleshooting glow plug circuit
JimJ
BX15 with front loader mower deck, B2601 with backhoe, bucket, forks, snow plow
Dec 9, 2010
Kalamazoo, MI
Looking for help troubleshooting glow plug circuit on old BX1500. Typical symptoms of harder to start as it gets colder, eventually won’t start when less than 25F. Glow plugs resistance measures good. I measure 0 volts at glow plug bus bar when key in on/preheat position. The glow plugs resistance measures light illuminates. I can’t find schematics to figure out the relay/timing eqp for the glow plugs. I’m thinking it’s built into the key switch?? Based on tracing wires. Any help or guidance is appreciated.
11,567
It does appear to be switch controlled and not relay controlled.
I would head to the switch and read the output of the switch.
3,102
"Glow plugs resistance measures good."
What value did you get in Ohms?
3,198
See the electrical schematic in post #3 in this thread
JimJ
Dec 9, 2010
Kalamazoo, MI
Thanks for the reply - took me a minute to find that there are replies after I posted. Flipped the notification switch for next time. Ended finding a 95% broken wire between switch and glow plug bus bar. Old girl starts like a champ now.
