BX 1880 owners, chime in
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,447
1,048
Minnesota
Anyone have the 60 inch mower with larger tires on? Currently have the 54 inch but remove it for winter duties. Also swap out the tires to the larger ones (23S) with R4’s. The 54 inch deck won’t mount with the the larger tires. Want to know if the 60 inch deck will work With the larger tires. The 60 inch deck is offered in the build on Kubota web site. Would like to keep my larger tires on year round. Thanks.
JoshBeshears
Oxford, AL
I'm with Beshears Kubota in Alabama.
I would not put a 60 inch mid-mount on a BX1880. Kubota's published implement limitations for the BX80 series cap the 1880 at a 54 inch mid-mount. The 60 is listed for the BX2380 and BX2680. Going over that can cause problems, and issues from an implement that isn't approved aren't covered by the warranty. I'd go by those limits, even if a 60 shows up in a build tool.
If the 54 already will not mount with your larger tires, a 60 is not the workaround I'd use on this tractor. For what it's worth, stock BX1880 tires are 16x7.50-8 in front and 24x12.00-12 in the rear. If you post the exact size off the sidewall of the larger set, that would help.
If you want the bigger tires on year round and a 60 inch mid-mount, that's really the next size tractor, a BX2380 or BX2680. On the 1880, the clean options are to run the 54 in the warmer months on the stock size tires, or look at a rear mower that's within the 1880 limits. That same chart caps a rear-mount mower at 48 inches on the 1880.
Bearcatrp
Mar 28, 2023
1,447
1,048
Minnesota
The tires are the same as the 23S. Guess I’ll consider other options. Why would Kubota list it as an upgrade if it won’t work?
JoshBeshears
Oxford, AL
I couldn't tell you why the site shows it. The build tools aren't always as tight as the implement limitations, and that chart is what warranty goes by. Before you spend money on a 60, ask your dealer to check the deck and your exact tractor against Kubota's current limitations. If they can show it's approved for the 1880, great. If not, I'd skip it.
Since the 54 won't clear those tires, your realistic choices are swapping tires seasonally like you've been doing, or a rear finish mower within the 1880 limits. If you're thinking about stepping up eventually, the new BX90 series is coming this spring... BX2190, BX2390 and BX2690, with some different configurations. I don't have all the details yet, but it might be worth waiting to see what they offer before you spend money on a deck.
PaulL
B2601, MX5200.
Jul 17, 2017
2,818
1,806
NZ
Is your BX1880 in warranty still? If not, warranty concerns aren't relevant.
Josh is giving good advice, but it's dealer advice.
My observation would be that the 1880 sits on the same frame as the 2380, and runs at the same revs. I can't think of what could break from running a 60 inch deck on it, since it's all the same gear that you get on the 2380 with a 60 inch deck. The wheels I think are a part of the limiting factor, but if you're putting the bigger wheels on, then you're close to 2380 spec.
The main issue I think is that you don't have enough power to run a 60 inch deck through thick grass. But that's something you can decide on for yourself - possibly your grass is very thin, possibly you plan to go slow so your machine doesn't bog down, possibly you plan to mow very often. The machine is sized and specced for the stupidest person who might possibly drive it, if that person isn't you then you may have some headroom.
Having said all that, I'm not sure second hand mowers are easy to come by, and new ones are expensive. Much like changing the FEL on a tractor, I'd guess it's cheaper to sell and rebuy than it is to try to add a bigger mower. And if you did that, you should go up a size too - get the B2601. Or even go all the way to the LX, then you can get a 72 inch mower and do things properly.
67Truckin
BX1800D, Massey Harris Mustang
May 25, 2016
80
Springfield, IL
I have a BX1800 that has the R4 tires on it and factory installed 60" mower deck. Been running good for 25 years now with no issues what so ever.
Bearcatrp
Mar 28, 2023
1,447
1,048
Minnesota
If I update, going for the LX2620 with a cab. Just need to win the lottery.
