Brand/type of electrical connectors ?
Farm Fun
L3902HST R14 tires, LA526 loader, LandPride QH16, LandPride 1060 combo bucket,
May 4, 2026
Missouri
What brand/type of automotive waterproof electrical quick-connect/disconnect connectors do you recommend? Thanks.
5,606
I don't have a specific brand name, but one thing I have found very useful is this little handheld crimper.
It works pretty well with those cheap Chines'ium "crimp style" connectors.
The one bad thing, is that it takes a pretty decent squeeze, to get it to work.
EDIT:
For waterproofing, I use the shrink tubing that has some sort of "magic glue" inside it. So when you heat it up, it softens the glue while simultaneously shrinking,....Thus creating a waterproof connection. 🤷‍♂️
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,260
1,144
Amsterdam, NY
EDIT:
I believe he wants "quick-connect/disconnect connectors".
Something like these:
Pawnee
L2501
Jul 1, 2021
379
346
Ontario Canada
These are excellent for power and ground. Available in 3 sizes with 30, 60, and 90 Amp ratings. I am a bit skeptical of the current rating but I use the XT-60 for 30 Amps in many applications.
They are not waterproof but they are gold flashed and unless you need something that will stand heavy spray or submersion I think they will be fine.
AliExpress
Those Deutsch ones look very nice, expensive, but probably worth the cost if you truly need waterproof or multiple contacts.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
569
191
NZ
Deutsch connectors the best, but you need a range of cable terminations and crimper dies depending on cable gauge. Definitely expensive.
I use the sort of crimper that RWT does, but avoid the pre-insulated cable terminations because I've found that its hard to be sure they are crimped firmly enough and none fit in connector blocks. In my opinion they are a fire risk. Instead, I use the uninsulated terminals (easy to see that you have a good crimp without having to tug on it) and use matching connector blocks (Hella, Utilux, etc).
For single cable connections I use insulated sleeves or adhesive heatshrink like RWT refers to.
Joisey
Kubota L47 TLB
May 31, 2015
261
185
Wild, Wonderful West Virginia
Just the Weatherpack connectors themselves to put on your wires are sold on Amazon. I have had zero problems with them over the years. Simple to use and cheap. And, they are reusable.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422, CanAm Outlander 650
Jun 29, 2011
401
542
SE, NM
Another pitch for NiLight and Deutsch. Deutch seemed to be better quality. The shrink tube RWS mentioned are worth it.
As always YMMV
jaxs
B1750HST
Jun 22, 2023
1,120
839
Shrink tube is the best solution I've found for connections that will not be unplugged. "Quick connect/disconnect" indicates they will be unplugged and plugged, in which case I use dielectric grease.
