B7100 Radiator Petcock
alanjd93
1992 B7100HST-D
Aug 9, 2026
Does anyone know what the radiator petcock thread is, and whether it uses thread sealant or some kind of o-ring/seal? I think it's M16x1.5 from some of the radiator listings online, but I can't confirm. OEM drain cock from Kubota is $80.
Looks like one of these may be a suitable alternative, if the thread is in fact 16mm.
Also found this aftermarket on ebay - a little better at $50, but still steep for a simple brass valve...
Caden
1979 B7100
Apr 16, 2026
431
251
Not sure how it seals. Mine is seized, I just pull the lower rad hose and don't worry with the petcock. Easier to get to than the petcock anyway.
I think if I were to try to remove/ replace mine I'd end up damaging the lower tank.
5,711
I have never seen a radiator drain that used sealant, so if i were betting, I would put my money on the "o-ring".
I usually try to use the petcock, but have used the "lower hose method" as well 🤷‍♂️
Both are usually "equally as messy"....I hate dealing with used coolant. It's probably easier to get rid of "spent nuclear rods" than it is to get rid of a gallon of used coolant......At least in my area.......Giant PITA
Never tried one of those fancy drain plugs though🤷‍♂️🤷‍♂️🤷‍♂️
Might be a good idea if they fit(y)(y)🍻🍻
alanjd93
1992 B7100HST-D
Aug 9, 2026
Thanks! Looks like I overlooked the simplest/cheapest solution... Maybe I'll just wait to replace it until the radiator goes.
alanjd93
1992 B7100HST-D
Aug 9, 2026
If it would work it seems like a solid option! Guess I just have to bite the bullet and attempt to remove the old one and measure the threads. If it doesn't seem like it's gonna go, I'm not gonna push it and just do the lower hose method. I would have guessed it would have been a taper pipe thread as there's no o-ring called out in the parts manual, and pictures I've seen of the Kubota part don't come with seal either. TractorpartsASAP and a few other sites listing radiators for sale say "M16 x 1.5 though, and it appears to be a straight cut thread. We'll find out! 🤷‍♂️
As for coolant - I feel your pain. Most of the auto parts stores around me are getting bad about used oil even. Either they're always full when I need to get rid of some OR they want your address, date of birth, ssn, first born, etc. before you can dump it. When you finally get behind the counter they watch you like you're a convicted felon seeing his parole officer for a drug test. Makes me want to get an oil burner to heat the garage and be done with it!
Gaspasser
L6060, FEL, forks, BB, rake, snowblower, KX033 mini-ex, dump truck, splitters.
Dec 16, 2023
480
766
NH
sweetbreezefarm.com
Used oil goes to AutoZone or O'Reilly. Local Kubota dealer takes my coolant. It may help that i buy oil and coolant there. Maybe a bit over priced but they do provide good, prompt service when needed and I'd like to keep it that way. I only have a mini ex and one tractor which are lightly used so not very expensive difference.
5,711
Yep.....The local O'riellys has a "permanant/temporary sign" posted that "claims" ;) they are full all the time.
As I think about it, most/many of the automotive ones, seem to be some sort of a "cam-lock" type mechanism.....
Good luck(y)(y)
