B1550 HST has hydraulic fluid getting into crankcase.
jgregan
B1550 HST
Aug 1, 2017
Waynesburg, PA
I've had my B1550 HST since new. Recently the tractor has issues with the fluid in the crankcase growing and spewing out of the breather tube. At the same time it's losing hydraulic fluid with no visible leaks. The Kubota service department claims that due to the tractor having a dry clutch it's impossible for hydraulic fluid to enter the crankcase. They have replaced the rings & the lift pump but that has not affected my problem at all. Any guidance or suggestions?
bucktail
Jun 13, 2016
1,299
221
MN
If your hydraulic pump runs off the gear by the injector pump, a bad seal on the hydraulic pump will dump hy-tran oil into your crankcase.
Vacula
BX1500, LA181, 54" MMM, JohnnyPlow Sr, Heavy Hitch, Box Scraper
May 10, 2017
76
Clinton County, PA
Interesting issue. I looked over the web for the issue as you described it and found no other question or complaint about hydro oil in the crankcase on any 1500 Kubota. (Nor other BX series Kubota).
11,376
Vacula,
It's a B not a BX, two completely different design of tractors.
The hydraulic pump is at the rear & is shaft driven
Jgregan,
Your hydraulic pump is on the back of the injection pump and is driven by the fuel cam, as bucktail pointed out you have a blown seal on the hydraulic pump and it's pumping hydraulic fluid into the motor.
jgregan
B1550 HST
Aug 1, 2017
Waynesburg, PA
Vacula,
Jgregan,
Thanks, replaced the seal & the o-rings while I had the pump off. Issue solved.
1970cs
1,124
Grand Ledge
FYI you need to find another Kubota dealer to do your service! They should be ashamed of themselves for not knowing that.
Pat
7,738
Wow, I read this, "The Kubota service department claims that due to the tractor having a dry clutch it's impossible for hydraulic fluid to enter the crankcase. They have replaced the rings & the lift pump but that has not affected my problem at all. Any guidance or suggestions?" and thought....what kind of service department does that dealership have?
You need to notify the principle owners of that dealership. Let them know the service you got, the charges they made to your account, and what they told you about it being impossible for the hyd. fluid to get in the crankcase. Then what the solution was, and how you found it, and you fixed it.
That is horrendous for a dealership service department!!
11,376
I was referring to the Kubota service tech reading the manual.
But I am sure some of them have posted under cover questions here. :rolleyes:
AWWW... Got YA, I was on the consumer side of thinking. :D
Porcello garage
Kubota B1550D
Jul 4, 2026
44
Enfield ct
I am having the same issue on my B1550D, where hyd oil is getting into my engine case. I see the IPC of the pump posted in the thread but i dont see any seals or o-rings. Does anyone happen to know where I can get the part numbers of the o ring or seal?
whitetiger
Nov 20, 2011
3,819
2,218
Kansas City, KS
31381-76190 pump input shaft seal
15231-87130 adapter to pump gasket
Jsjac
B2650
Feb 13, 2022
248
410
You might also check the bushing in the front section of the pump. Maybe the pump has a little bit of shaft play.
