A little wild life
5,763
Question for to collective . With colder weather coming and maybe a handle on the critters, I was thinking about water for the birds. I wonder if any one has made a heated bird bath just enough to keep the water from freezing. I have seen heated bird baths but I figure it would be more fun as a DYI project. So if you did one or have an idea pop it in here maybe someone scan profit too.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,119
2,540
WestTn/NoMs
I first tried something else, can't remember exactly what, but ended up with one of these. It's 44 watts.
They would work well in a flat bottomed bath, but mine had a raised island in the bottom, so the heater couldn't sit flat. So I made a ring out of concrete with a depression to hold the heater and put the bowl on top. There's a hole for the plug to exit. At 44 watts, it won't burn out exposed to the air. I put a little plug-in thermostat on it for some reason. It worked ok in west Tn, but would probably need to be insulated in your climate, maybe make it with perlite or vermiculite?
This setup, less the thermo unless I find it, is available for a very reasonable price, buyer pickup.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,240
1,217
E.
a small fish tank heater is very common at pet shops placedmin whatever bowl you choose can work
a really small one is only 7 watts and they get as big as you want
used on facebook etc... very common
GrumpyFarmer
5,310
I think a trip to TSC or Rural King or what ever farm store you might have close should be able to get you outfitted.
Livestock needs water daily and it doesn’t matter whether that is for chickens goats cows dogs whatever. Farm store should have something. (Heated pads for under something, submersible elements, heat bulls/buckets/tanks)…if you really wanted to set up some type of exclusive resort for your chicks, I bet they would even like a brooder plate to cuddle up next to.
Whether the solution is visual appealing for you or not may be a different story. But there are plenty of low cost options at a farm store.
