900X turbo install. Has anyone done one?
Glenn S
RTVX900, NH Boomer 50, Cub Cadet TRS, JD 350C, IH 584 and attachments
Oct 20, 2018
Alberta
Hi, I am wondering if anyone out there has installed a turbo on an 900X . My model is a 2017 and I would like more power for hill climbing, as well our altitude is 3500 ft so a turbo would help.
I wonder if the rest of the machine, hyd pumps, transmission final drives, cooling system will handle the extra power. The turbo model should be around 32 HP vrs 22HP stock.
The 1140 model has a 1.1 liter engine and is rated at 25 HP, all other components are the same as the 900X, so we know it can take that much HP.
Any ideas on this is appreciated.
Thanks to all
Glenn S
Oct 20, 2018
Alberta
It’s definitely been done and I’d start by taking a look at these guys;
Mike
Mike I saw this and that's what started my thinking. I looking for real world experience from some one who has done it, example any mechanical failures or operational issues such as over heating.
Rdrcr
Vendor Member
May 7, 2021
780
982
WA
I personally don’t know anyone, or have read about anyone installing one of these kits.
However, if it were me, I’d reach out to the manufacturer and see if they can put you into contact with a customer or point you towards some reviews of their kit on a 900x.
My L2501 is turbocharged, I haven’t experienced any issues with over heating…and all other members here, who have also turbocharged their tractors, have not experienced any over heating issues.
Mike
Oil pan 4
L185 turbo
Sep 21, 2017
418
119
NM
I boiled, not over heated my turbo intercooled L185 once mowing 4 to 5 feet tall green tumble weeds with my 48 inch brush shredder, but I was running straight water in the cooling system. Added about 20% to 25% coolant now it's good.
Also the L185 doesn't have a coolant pump, coolant circulation is provided by convection only.
5,515
2,231
I've done two X1100's. Ain't worth the money unless you're at high (10,000 ft+) altitude. Very disappointing. It does work and does make ever so slightly more power but don't expect a daylight-and-dark power increase like they advertise.
Glenn S
Oct 20, 2018
Alberta
Thanks, this is the type of real-world experience I was looking for. From what the turbo suppliers say the performance would 35-50 % better.
I'll keep the $3000 in my pocket.
drewzee87t
L45 TLB, B2910 Turbo
May 20, 2016
176
94
Canadastan
ATV turbo kits work great but you need to do a lot of other work with the hydro pressure reliefs, manual throttle and fueling. The net result is that if you wanted that you should have gotten a gas powered atv to begin with.
Jchonline
600
Red Feather Lakes, CO
I agree with this. I am at 9000ft and ran my X1100C non-turbo for 2 years, then got a turbo installed.
The turbo is NOT night and day power/speed difference. The sluggishness of the X1100 is just the HST...they arent designed to zip around. However once warmed up I do notice it being improved up hills...just not a massive improvement.
However, there is a night and day difference in starting. It cranks right up now...and before It took me minutes to get it started.
Overall glad I got it done, but its not a huge change I agree.
Little General
Kubota x1100c , Kubota KX008
May 19, 2019
24
21
Mt Pleasant, NC
Little General
May 19, 2019
24
21
Mt Pleasant, NC
I’m near 1000’ here in NC and was seriously thinking of putting a turbo kit on my x1100c. I have a couple hills that when the ac is on , it bogs down. I understand it’s not going to pull the front wheels off the ground , but it has to help. Or does it?
11,477
It will help about [] this much.
SDT
Apr 15, 2018
3,719
1,441
Thanks to all
Why not just trade it in on an 1100?
Everything will work as intended and will have a warranty.
Might not cost much more after everything considered.
