2007 L3400 cruise control shaft seal replacement
SKOR
L3400
Jul 28, 2026
Central Oregon
Has anyone replaced the left-hand side cruise control/foot pedal seal on an HST transmission. Mine is slowly dripping oil and I’m getting conflicting information on how to replace it. It looks like the linkage arm is welded to the shaft and there’s a cotter pin right next to the casting on both the right and left side. I think the cotter pins are there to keep the shaft centered in the transmission. When looking at a parts diagram, the shaft appears to go completely through the transmission and I would have two remove the whole piece in order to replace the seal. Any help would be appreciated.
whitetiger
Nov 20, 2011
3,820
2,218
Kansas City, KS
Your analysis is correct; you do have to remove the shaft completely to replace the LH seal.
11,379
Post for the visual readers!
Note: They are not cotter pins, they are roll (spring) pins.
SKOR
L3400
Jul 28, 2026
Central Oregon
Thank you for the answer and thanks for the picture! Is there anythingI should try to fix the seal before biting the bullet and pulling the shaft? Does a shaft support any internal parts or does it just go straight through the casing?
11,379
Nope no magic non-replacement fix.
No it doesn't connect to anything internally.
Yank it out and replace both seals.
Note: If the shaft has excessive wear on it, you might need to replace it to get it to seal properly.
