1973 L210 Transmission Oil Capacity
highiron
L210
Apr 22, 2024
9
western oregon
It was my apparent incorrect belief that the transmission and the differential share a common oil sump. I had a problem with the tractor getting stuck in 3rd gear. Removed the shift lever and slid the fork back to correct position, but noticed the dreaded grey of powdered metal and oil on the ball of the shift lever. Made a dipstick and found about two inches of oil. I have the owners manual and the service manual and nowhere does it mention changing the transmission oil. The 13.6 quarts in the diff was due to be changed , so drained it. the level in the trans remained the same. So apparently not connected. Found a trans drain plug and drained out a quart of very different colored 90W. Thankfully with no evidence of metal powder. My experience has always been that the gears throw oil all over the inside of the trans. There is no overflow plug to confirm the correct level. I talked to three service departments that were unable to provide any help. If the two chambers are supposed to be connected with open style ball bearings to provide oil passage, could someone have replaced them with sealed bearings and blocked the passage of oil between the two? It makes no sense that there would be no way to check the oil level in the trans. The oil level on the dipstick behind the shift lever was on the mark, and I measured the oil I drained out and it was the exact 13.6 quarts mentioned in the service manual. With apologies for the long post, I remain puzzled. any help out there???
Sincerely, Ron
3,173
The L210 is similar but different than my L185. But I believe the rear differential and the transmission case are all one sump.
The L210 is not covered in the workshop manual I have so I am very hesitant to make any definitive statements about it.
There is a work shop manual to down load at this SITE
This is the index of Kubota books dot com. They are free but the site asks for a donation to help keep it running. Supposedly the site may have trouble with pop up scams trying to charge for the information so I provide a link to the index page that shows the L210 in two different places
highiron
L210
Apr 22, 2024
9
western oregon
highiron
L210
Apr 22, 2024
9
western oregon
Thank you for your prompt reply. I already have the documentation that you referenced. There is no information there that indicates that The transmission is separate from the final drive/differential.
3,173
You can call this company in California since they deal with the older L series tractors. @007kubotaguy is a member here and is involved with that company.
11,355
Yea that's all one sump, if it's not moving fluid all around the cases, you need to tear into it and clean it all up as it's probably crud that's plugging up the bearings.
whitetiger
Nov 20, 2011
3,810
2,211
Kansas City, KS
The L210 may have two different oil reservoirs; see the pages below from the L210 WSM.
I have not seen one since before we had dirt, just played in the rocks with it. ;)
