Kubota K Connect Snowblower problems explained.
Have you experienced excessive wear in your K Connect connection parts?
  • Yes
  • No
  • Have you experienced a broken retaining bolt of the K Connect drive system?
  • Yes
  • No
  • Have you experienced any other problems that haven't been discussed with your K Connect Snow blower?
  • Yes
  • No
Results are only viewable after voting.
5,583
yes...
when you attach the snowblower or broom, you use the lever to mechanically connect the two dog clutch halves.
when you turn On the mid mount PTO, THAT spins all the shafts, ujoints clutch and of course sends power to the snowblower or broom
So when you engage the blower, what cushions those "ears"?
It cant be nothing? Can it?
Is it really 2 pieces of steel that slam together because of that "giant gap" between them?
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
351
665
NH/VT NEK
It is exactly that as far as I can tell. There is nothing to cushion it other than the fact you engage the PTO at idle, but whatever force that PTO applies at idle when engaged is what those two dogs experience 100%.
Unless I am missing something significant. There is no clutch or slippage mechanism whatsoever.
EDIT: BTW, I have not heard back from Rad Tech regarding my email and pictures. I can't say I am surprised but it has also only been a day or so.
5,583
OMG......thats nuts.
Kubota Engineers at the bar.......
6,329
you're supposed to engage PTO at low RPM not at full throttle( that's written in a manual somewhere).
Last year when this 'reared it's ugly head', I suggested replacing the $700 parts with a 'Lovejoy' style coupling ,for about 1/3rd the cost and it'd last decades.
5,583
Yea I agree.
maybe find a "Lovejoy" spacer/cushion that would fit?
5,164
There is no way to install a Lovejoy coupling in the assembly.
Mowbizz
Bx25d
Aug 19, 2021
637
360
Crappy design for sure…I feel bad you guys are going through this BS and at the same time, grateful that I have the old style connections where you connect everything (still sometimes a pita reaching into the small blower-to quick hitch area) and it stays that way for the season. ( I stayed with my quick hitch connection for an hour and finally got it on the splined shaft with difficulty but once connected, done until Spring)
Your problem is very convenient but obviously, needs to be re-engineered.
Michford
2018 Kubota B2650HSDC
Aug 24, 2022
21
29
I would sure be trying to modify and incorporate a lovejoy coupling into the poor design. Can't believe anyone could ever think metal to metal slamming together would not be a problem in this situation. Even if a guy had to modify the existing parts to add modified lovejoy parts, it seems like a better system could be done.
Lovejoy
6,329
As I posted last winter,it is possible to install 'Lovejoy ' style couplings...seems 'Lovejoy' is a brand,like Xerox for photocopy... I know I saw some ( 2 halves and the 'rubber') and less than $200. Back then I was pretty sure the 'coupling' does NOT need to bend as there's a Ujoint before and after it,so Kubota saying to NOT raise the blower didn't make any sense.
I don't have that setup, neighbour does, so I'll probably see it in 2-3 months when his fails. I KNOW he won't want to spend $700 for the 3 parts, that WILL fail.
5,164
The shaft on the older units is not a perfect square, but a rectangle. What I did was to cut a small V in both mating parts, and when ti came time to mate them up, I just made sure to match the Vs that I had cut into the metal with a file. Another option would be paint, but that can get rubbed off.
Donystoy
Dec 10, 2013
741
384
Binbrook, Ontario
So far my coupling is fine but I have only used it a couple of times last winter. If it starts to fail, my plan is to remove the spring loaded engage assembly and just weld the coupling together. That way it will be basically like the blower I had on the B7200 with the drive shaft just sliding apart or separating it from the mid pto when removing the blower from the tractor. The only issue I had with the blower was that the discharge impeller was seized onto the shaft. Would not have broken a shear bolt if it hit a boulder.
6,329
If you can weld the coupling together ,that means it does NOT 'bend' as the blower is raised or lowered, so WHY does Kubota say 'not to raise too high, or while USING it '???
River19
Sep 10, 2020
351
665
NH/VT NEK
Did Kubota ever really say to not raise the blower? I know no where in my documentation
Maybe I am experiencing missing time, where does Kubota say not to raise it while running the blower? I know if doesn't state that in the manual for the K-Connect or Blower......
Donystoy
Dec 10, 2013
741
384
Binbrook, Ontario
There is no angular movement in this coupling when raising or lowering the blower. That is all taken care of with the drive shaft.
6,329
last year there were several 'threads' about the Krappy Konnect system...many posted about K saying NOT to raise the blower when powered and while I'm 70 I do REMEMBER those posts, even somehow found manuals and yes, it's specifically states do NOT lifting/lowering the blower. Made no sense to me UNLESS that coupling is at the 'pivot' joint, but it's not according to Donystoy post above.
So it boils down to Kubota's K-maker did a LOUSY job engineering the K-connect system. $700 for 2 couplings is, well, highway robbery, plain and simple
If someone knows how much HP actually gets transferred to the blower, RPM, shaft sizes, it's not that hard to locate a 'Lovejoy' type coupling that could be 'bolt on simple' to install
What I love to know is WHY the fancy CNC machined couplings that do NOT mesh properly ! ?
Bearcatrp
Mar 28, 2023
1,405
1,017
Minnesota
Would think if it’s in the manual not to raise the snowblower, probably best to disengage pto before raising it. Still dumb but if that stops replacing this part every year at $700 a pop, then I would do this.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
I raise and lower mine every time I go forward or backwards., My blower is the BX2830 (no, not a typo)
Out by the (very busy) road, I even backdrag with downpressure (like you would with a bucket)
Front wheels of BX sometimes right off the ground.
I probably have 35-40hrs on the blower itself.
No wear (or not much, afaict)
I cannot explain how mine seems to be in at least "good" shape. I never baby the thing and boy do we get snow here in NB, Canada.
I have not done extensive testing, but I don't believe there is measurable movement at this coupling when I raise/lower the blower. I could always be wrong.
Michigankubota
B2650 Loader,LX 2980-64 Blower ,60”MMM , Land Pride 60”Box Blade.
Oct 17, 2018
246
14
Bessemer, Western U.P.
I picked up my LX 2980 in a crate, assembled and installed myself. The blower is made in Canada. the driveline crate had a big label “MADE IN CHINA”. Hope mine lasts 🤔😐.
4,161
2,854
